MAX92 93 Posted February 12, 2025 Posted February 12, 2025 Pour ceux qui ont un certificat Let's Encrypt sur leur Synology, voici un script pour le transformer automatique en fichier P12 pour être utilisé par EMBY #!/bin/sh # CONFIGURATION #script_folder=/volume2/Emby backup/Certificats à conserver script_folder=/volume2/video # p12 file p12_file_path=$script_folder/certificate_auto.pfx # Synology's Default Let's encrypt folder letsencrypt_cert_folder=/usr/syno/etc/certificate/system/default # renew timestamp renew_timestamp=renew_emby_timestamp.txt # p12 password p12cert_password=EMBY # DO NOT CHANGE BELOW UNLESS YOU'RE A WIZARD generate_p12=false current_date=`date +"%s"` current_certificate_date=`openssl x509 -enddate -noout -in $letsencrypt_cert_folder/RSA-cert.pem | cut -d'=' -f2` current_certificate_timestamp=`date -d "$current_certificate_date" +"%s"` # check if the renew_timestamp file exists if [ ! -f $script_folder/$renew_timestamp ]; then echo "Generate timestamp for the current renew date... " echo $current_certificate_timestamp > $script_folder/$renew_timestamp chmod +rw $script_folder/$renew_timestamp chown admin:users $script_folder/$renew_timestamp # generate the first p12 file generate_p12=true else renew_date=`cat $script_folder/$renew_timestamp` # check if it is necessary to renew the certificate or not if expr "$current_date" ">" "$renew_date" > /dev/null; then # generate a new p12 file echo "Renewing certificate..." generate_p12=true # update timestamp in the file echo $current_certificate_timestamp > $script_folder/$renew_timestamp else echo "It is not necessary to renew the certificate, abort." exit 0 fi fi # generate a new certificate file if necessary, and restart EMBY Server if expr "$generate_p12" "=" "true" > /dev/null; then echo "Generating the p12 certificate file..." openssl pkcs12 -export -in $letsencrypt_cert_folder/RSA-fullchain.pem -inkey $letsencrypt_cert_folder/RSA-privkey.pem -out $p12_file_path -password pass:$p12cert_password chmod +r $p12_file_path chown admin:users $p12_file_path echo "Restarting EMBY Server..." synopkg restart EmbyServer echo "Done." fi A lancer en "Root" quotidiennement 1 1
massilliaman 4 Posted February 13, 2025 Posted February 13, 2025 Salut, dommage ca manque un peu d'information sur la partie # CONFIGURATION pour les gens comme moi, qui sont un peu juste en informatique
MAX92 93 Posted February 13, 2025 Author Posted February 13, 2025 # CONFIGURATION #script_folder endroit où tu veux mettre ton certificat pour EMBY script_folder=/volume2/video # p12 file Nom du certificat pour EMBY p12_file_path=$script_folder/certificate_auto.pfx # Synology's Default Let's encrypt folder letsencrypt_cert_folder=/usr/syno/etc/certificate/system/default # renew timestamp renew_timestamp=renew_emby_timestamp.txt # p12 password Mot de passe du certificat pour EMBY p12cert_password=EMBY
yohan_g 2 Posted May 4, 2025 Posted May 4, 2025 (edited) Merci pour le script, cependant pour moi il ne fonctionnait pas. J'ai réussi à appliquer une correction qui fonctionne avec l'aide de Copilot Pour les détails: - J'ai créé un répertoire partagé dédié: /volume1/Emby-certs - J'y ai créé en SSH (avec le compte root) le script corrigé "Emby_certs_from_dsm.sh" et copié/collé le script ( vi /volume1/Emby-certs/Emby_certs_from_dsm.sh )=> cela évite des erreurs due au format du fichier lorsque créé depuis un ordinateur et déposé dans le répertoire partagé - (optionnel) Vérifié en SSH (avec le compte root) le bon fonctionnement du script, en tapant simplement /bin/bash /volume1/Emby-certs/Emby_certs_from_dsm.sh - Créé une tâche planifiée exécutée avec le compte root, avec la commande: /bin/bash /volume1/Emby-certs/Emby_certs_from_dsm.sh - Lancé une fois la tâche et vérifié dans le répertoire partagé que le certificat apparait - Configuré Emby pour récupérer le certificat généré (mot de passe du certificat configuré dans le script: "EMBY") Le script corrigé (vous pouvez ne modifier que l'emplacement du répertoire où se trouve le script, pour le reste, inutile de modifier): #!/bin/sh # CONFIGURATION script_folder="/volume1/Emby-certs" p12_file_path="$script_folder/certificate_auto.pfx" letsencrypt_cert_folder="/usr/syno/etc/certificate/system/default" renew_timestamp="renew_emby_timestamp.txt" p12cert_password="EMBY" # DO NOT CHANGE BELOW UNLESS YOU'RE A WIZARD generate_p12=false current_date=$(date +"%s") current_certificate_date=$(openssl x509 -enddate -noout -in "$letsencrypt_cert_folder/RSA-cert.pem" | cut -d'=' -f2) current_certificate_timestamp=$(date -d "$current_certificate_date" +"%s") # Vérifier si le fichier renew_timestamp existe if [ ! -f "$script_folder/$renew_timestamp" ]; then echo "Generate timestamp for the current renew date... " echo "$current_certificate_timestamp" > "$script_folder/$renew_timestamp" chmod +rw "$script_folder/$renew_timestamp" chown admin:users "$script_folder/$renew_timestamp" # Generate the first p12 file generate_p12=true else renew_date=$(cat "$script_folder/$renew_timestamp") # Check if it is necessary to renew the certificate if [ "$current_date" -ge "$renew_date" ]; then echo "Renewing certificate..." generate_p12=true echo "$current_certificate_timestamp" > "$script_folder/$renew_timestamp" else echo "It is not necessary to renew the certificate, abort." exit 0 fi fi # Generate a new certificate file if necessary and restart EMBY Server if [ "$generate_p12" = "true" ]; then echo "Generating the p12 certificate file..." openssl pkcs12 -export -in "$letsencrypt_cert_folder/RSA-fullchain.pem" -inkey "$letsencrypt_cert_folder/RSA-privkey.pem" -out "$p12_file_path" -password pass:"$p12cert_password" chmod +r "$p12_file_path" chown admin:users "$p12_file_path" echo "Restarting EMBY Server..." synopkg restart EmbyServer echo "Done." fi Edited May 4, 2025 by yohan_g 1 1
