gensoto1990 1 Posted February 13, 2025 Author Posted February 13, 2025 4 hours ago, user24 said: Hi, I had a very similar problem a couple of months ago when I needed to replace my modem/router and essentially set up a whole new home network. (Though, I am using a Windows PC for the Emby Server, and a Synology NAS for media storage, not Mac.) After connecting all devices, Emby would work correctly on the PC, but I could not cast to my TV or music player (or even see the endpoint devices in the cast options). Also, Emby Android on the TV would not see the server, despite manually entering the server address correctly. The problem was that Windows, with the new network, was now blocking Emby from getting through the firewall. I found this by going into the Windows Settings>Privacy & security>Firewall & network settings. (I'm not a networking expert so can't really provide more specific details and a MacOS setup would be different anyway.) I also have dynamic IP addresses, but have not had any more issues (so far, for in-home use) since adjusting the firewall settings and giving Emby permission. I found out how to fix my problem via the green "Connection Help" section shown in your previous screenshot. Perhaps checking your firewall settings is something to try, if you haven't already? Exactly, I need all that but on a Mac cause I have zero idea where to even begin.
gensoto1990 1 Posted February 13, 2025 Author Posted February 13, 2025 I noticed that I have my Firewall off on Mac as well. The thing I bet it's the issue is that whole dynamic IP crap that I just can't find anywhere
gensoto1990 1 Posted February 13, 2025 Author Posted February 13, 2025 18 hours ago, user24 said: Hi, I had a very similar problem a couple of months ago when I needed to replace my modem/router and essentially set up a whole new home network. (Though, I am using a Windows PC for the Emby Server, and a Synology NAS for media storage, not Mac.) After connecting all devices, Emby would work correctly on the PC, but I could not cast to my TV or music player (or even see the endpoint devices in the cast options). Also, Emby Android on the TV would not see the server, despite manually entering the server address correctly. The problem was that Windows, with the new network, was now blocking Emby from getting through the firewall. I found this by going into the Windows Settings>Privacy & security>Firewall & network settings. (I'm not a networking expert so can't really provide more specific details and a MacOS setup would be different anyway.) I also have dynamic IP addresses, but have not had any more issues (so far, for in-home use) since adjusting the firewall settings and giving Emby permission. I found out how to fix my problem via the green "Connection Help" section shown in your previous screenshot. Perhaps checking your firewall settings is something to try, if you haven't already? So, I think what he's saying is the root of all evil in this case. Can someone with a Mac help me to do this on my Macbook cuz I have no idea, I mean I did look around online and it's just very confusing to me if I'm being honest.
Luke 42237 Posted February 14, 2025 Posted February 14, 2025 Are you able to access the macOS server from other device inside your local network?
gensoto1990 1 Posted February 14, 2025 Author Posted February 14, 2025 (edited) I can play Emby on my Mac and even with Kodi as well and the FireStick. It’s the Sony OLED and the 4K Sony player that does not do anything even though when I had my old router it never NEVER had an issue (I even bought a new MacBook and I could just download Emby and it played fine) Edited February 14, 2025 by gensoto1990
visproduction 335 Posted February 14, 2025 Posted February 14, 2025 Sony owners have posted this solution to no Internet connection. It may work for your TV. Settings>Network>Advanced Settings>IPv6 setup>Disable IPv6 Perhaps the TV was reset or you got an automatic Sony online update. Sometimes, that can change your setup enough and it seems like nothing has changed. This also can happen with computer OS updates which can result in suddenly things stop working.
gensoto1990 1 Posted February 14, 2025 Author Posted February 14, 2025 I’ve reseted my 4K Sony Player and still nothing.
gensoto1990 1 Posted February 14, 2025 Author Posted February 14, 2025 4 hours ago, visproduction said: Sony owners have posted this solution to no Internet connection. It may work for your TV. Settings>Network>Advanced Settings>IPv6 setup>Disable IPv6 Perhaps the TV was reset or you got an automatic Sony online update. Sometimes, that can change your setup enough and it seems like nothing has changed. This also can happen with computer OS updates which can result in suddenly things stop working. Nothing on there either.
gensoto1990 1 Posted February 14, 2025 Author Posted February 14, 2025 (edited) So, this is my FireStick 4K right now: Notice the Emby & Servio logo clearly represented and can access my files just fine. Now watch my Sony XR 77a80K OLED: For some reason, Kodi is represented and when I click it, guess what, cannot access bupkis. And finally, my 4K Sony Blu-Ray: Same as above. This is my new Modem: (A Sagemcom) So anyone who has this info could help, would be very appreciated… Edited February 14, 2025 by gensoto1990
Luke 42237 Posted February 15, 2025 Posted February 15, 2025 So at this point Emby is good and you just have a problem with Kodi?
gensoto1990 1 Posted February 15, 2025 Author Posted February 15, 2025 Quite honestly it’s the router. That’s what’s been building up. I’m going to change it again later this week.
Solution gensoto1990 1 Posted February 16, 2025 Author Solution Posted February 16, 2025 All right, so I changed the router, now it works. If any of you have a Mac and this happens, you have to change the router. 1
