kjcraw4d 3 Posted February 9, 2025 Posted February 9, 2025 Is there a setting that I'm missing that would allow the auto-display of lyrics (.lrc files) that have been downloaded? When I search Google, I see this (AI generated result): To turn on automatic lyric display in Emby, navigate to your Emby server settings, go to the "Music" section, and then enable the "Auto-display lyrics" option; this will automatically show lyrics when playing a song that has lyrics associated with it. Key points to remember: Access settings: Open your Emby server settings on your preferred device. Music section: Go to the "Music" tab within the settings. Auto-display lyrics toggle: Find the "Auto-display lyrics" option and switch it to "on". Does this setting actually exist for Android phone/TV devices? I've looked on my Android phone and on my Android TV box (not using the old 'for Android TV' app) and can't find it.
Luke 42301 Posted February 14, 2025 Posted February 14, 2025 Hi, normally if you enable the lyrics, then the app should remember that. Is that not what you're seeing?
kjcraw4d 3 Posted February 14, 2025 Author Posted February 14, 2025 I do see the lyrics icon for those titles that have lyrics files available. I realize that after selecting the lyric icon during playback, any subsequent files with lyrics will display them, but when a file has no lyrics, the display defaults back to album images - and the next time a file with lyrics comes up for playback, I have to select the lyrics icon again. I was hoping that there was some setting or way to have those files with lyrics automatically display the lyrics without having to select the lyric icon. Files without lyrics could/would display the album image. It may not be possible/feasible, but wanted to ask...or maybe add to a "like-to-see" list for a future upgrade. FWIW, I use the lyric feature mostly on my two SHIELD pros, my onn pro 4k, and my new Google TV Streamer 4K boxes.
Luke 42301 Posted July 26, 2025 Posted July 26, 2025 @kjcraw4dOK we will look at this for the next set of updates to Emby apps. Thanks.
