bandit8623 226 Posted February 9, 2025 Posted February 9, 2025 (edited) Hello, previously i have made custom channel lists and had no guide data, but my provider changed all urls... so setting up again. but emby is not pulling any epg data. Can someone let me know what im doing wrong? ill try adding my steps. add m3u ignore the m3u fil name diff. above is example. but same format should data be pulled in? im obviosuly missing something in formatting? ive tried changing the tvg-id to the ones below no change. Thanks Edited February 12, 2025 by GrimReaper Img removed
Carlo 4561 Posted February 11, 2025 Posted February 11, 2025 Hi @bandit8623 #EXTM3U url-tvg="http://www.teleguide.info/download/new3/xmltv.xml.gz" #EXTINF:-1 group-title="Science", Discovery http://example.com/channel1 #EXTINF:-1 group-title="Sport", Eurosport http://example.com/channel2 #EXTINF:-1 tvg-logo="Eurosport" tvg-name="Eurosport" tvg-shift="+1",Eurosport +1 http://example.com/channel3 #EXTINF:-1 group-title="Custom" tvg-logo="https://cdn1.iconfinder.com/data/icons/Primo_Icons/PNG/128x128/video.png",My Custom channel http://example.com/channel4 Take a look at the above, then have a look at your m3u fille. Notice the format of the url-tvg tag above points to the guide data. 1
bandit8623 226 Posted February 11, 2025 Author Posted February 11, 2025 3 hours ago, Carlo said: Hi @bandit8623 #EXTM3U url-tvg="http://www.teleguide.info/download/new3/xmltv.xml.gz" #EXTINF:-1 group-title="Science", Discovery http://example.com/channel1 #EXTINF:-1 group-title="Sport", Eurosport http://example.com/channel2 #EXTINF:-1 tvg-logo="Eurosport" tvg-name="Eurosport" tvg-shift="+1",Eurosport +1 http://example.com/channel3 #EXTINF:-1 group-title="Custom" tvg-logo="https://cdn1.iconfinder.com/data/icons/Primo_Icons/PNG/128x128/video.png",My Custom channel http://example.com/channel4 Take a look at the above, then have a look at your m3u fille. Notice the format of the url-tvg tag above points to the guide data. ah thanks. looks like provider doesnt provide an epg
Kcircuit 6 Posted February 11, 2025 Posted February 11, 2025 On 09/02/2025 at 12:35, bandit8623 said: Hello, previously i have made custom channel lists and had no guide data, but my provider changed all urls... so setting up again. but emby is not pulling any epg data. Can someone let me know what im doing wrong? ill try adding my steps. add m3u ignore the m3u fil name diff. above is example. but same format should data be pulled in? im obviosuly missing something in formatting? ive tried changing the tvg-id to the ones below no change. Thanks Might want to cover up your m3u details there.
bandit8623 226 Posted February 11, 2025 Author Posted February 11, 2025 19 hours ago, Kcircuit said: Might want to cover up your m3u details there. thank you. @Carlocould you have someone remove pic? @Abobader 1
Abobader 3485 Posted February 12, 2025 Posted February 12, 2025 Hey @LukeIt already been removed by our mod's team @GrimReaper 2
