miketunes 0 Posted February 9, 2025 Posted February 9, 2025 Ember doesn't seem to be detecting them, is there a certain type of media I need to set it as?
Abobader 3484 Posted February 9, 2025 Posted February 9, 2025 Hello miketunes, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42180 Posted February 9, 2025 Posted February 9, 2025 Hi there, can you please provide a specific example? Thanks.
miketunes 0 Posted February 9, 2025 Author Posted February 9, 2025 11 hours ago, Luke said: Hi there, can you please provide a specific example? Thanks. Sure - https://drive.google.com/file/d/1D3vFPRMrJxhhaa3K3lTszkD0-h_BUyNm/view?usp=sharing
ebr 16306 Posted February 9, 2025 Posted February 9, 2025 Hi. You setup a library of type "Music" and it contains MKV files?
miketunes 0 Posted February 9, 2025 Author Posted February 9, 2025 5 minutes ago, ebr said: Hi. You setup a library of type "Music" and it contains MKV files? Yes, but when I go to browse it it's empty. I tried Music Videos also and still empty.
Happy2Play 9798 Posted February 9, 2025 Posted February 9, 2025 1 hour ago, miketunes said: Yes, but when I go to browse it it's empty. I tried Music Videos also and still empty. May have to elaborate on library setup. But yes there are still limitations to ffpmeg/ffprobe.
miketunes 0 Posted February 9, 2025 Author Posted February 9, 2025 Ah great you got it working, I just did the defaults - fresh install of Emby. So you got it working as music media type, did you check certain scanning options?
rbjtech 5335 Posted February 10, 2025 Posted February 10, 2025 Unless the MKV has a video stream, then they should be MKA files. If they are MKA, then Emby should (I believe) pick them up in them up in an Audio/Music library. If MKV, then it will ignore them (by design). If MKV, test this, but you should literally be able to rename the files as MKA without any further processing required.
miketunes 0 Posted February 10, 2025 Author Posted February 10, 2025 3 hours ago, rbjtech said: Unless the MKV has a video stream, then they should be MKA files. If they are MKA, then Emby should (I believe) pick them up in them up in an Audio/Music library. If MKV, then it will ignore them (by design). If MKV, test this, but you should literally be able to rename the files as MKA without any further processing required. Gotcha - yes I believe that will work, I wonder how Happyp2play was able to add them without renaming.
