Alepim 9 Posted February 8, 2025 Posted February 8, 2025 Hi! When I download to iPad it says that it is ready to transfer, but it does not download. When I try to watch on iPad it says that there are currently no compatible streams. Everything worked fine before, I tried to fix something in the settings and everything stopped working. I tried to reinstall the server and the client - it did not help.
Alepim 9 Posted February 8, 2025 Author Posted February 8, 2025 (edited) approximately done at 8 - 9 o'clock name: alepim hardware_detection-63874629092.txt.crdownload embyserver.txt.crdownload Edited February 8, 2025 by Alepim
Carlo 4561 Posted February 12, 2025 Posted February 12, 2025 Hi, The log you uploaded only covers the timespan 2025-02-08 16:31 to 2025-02-08 17:24. Carlo
Alepim 9 Posted February 12, 2025 Author Posted February 12, 2025 1 hour ago, Carlo said: Привет, Загруженный вами журнал охватывает только период с 2025-02-08 16:31 по 2025-02-08 17:24. Карло Thank you! the problem arose immediately after installation. But, it seems, the solution to the problem is port forwarding on the router. 1 1
