MikaelKW 7 Posted February 4, 2025 Posted February 4, 2025 Hi, When users login to my Emby server remotely (i've also tried this locally by just adding the remote adress, instead of the local IP), the next time they open the app they have to sign in again. Is it possible to stay signed in when login in remote. It works perfect when i access the server from a local IP.
GrimReaper 4898 Posted February 4, 2025 Posted February 4, 2025 Which client app, AndroidTV or Standard Android app?
GrimReaper 4898 Posted February 4, 2025 Posted February 4, 2025 What is their Login behavior set under app settings>Startup tab?
ebr 16336 Posted February 4, 2025 Posted February 4, 2025 34 minutes ago, GrimReaper said: What is their Login behavior set under app settings>Startup tab? And, exactly how are they exiting the app? If they choose "Log out" they will have to log back in.
MikaelKW 7 Posted February 4, 2025 Author Posted February 4, 2025 43 minutes ago, GrimReaper said: What is their Login behavior set under app settings>Startup tab? Oh wow. I actually had no idea this was a setting in the app. Thanks! @LukeWhat do you think about a checkbox on the initial login screen, where you can choose to stay logged in?
Luke 42243 Posted February 4, 2025 Posted February 4, 2025 2 minutes ago, MikaelKW said: Oh wow. I actually had no idea this was a setting in the app. Thanks! @LukeWhat do you think about a checkbox on the initial login screen, where you can choose to stay logged in? Hi, it's there and called "Remember Me".
MikaelKW 7 Posted February 4, 2025 Author Posted February 4, 2025 (edited) 9 minutes ago, Luke said: Hi, it's there and called "Remember Me". For the "Emby for Android TV" app? I may be blind but i can't see it when i log out. Edited February 4, 2025 by MikaelKW
ebr 16336 Posted February 4, 2025 Posted February 4, 2025 27 minutes ago, MikaelKW said: For the "Emby for Android TV" app? It is not on the login screen in that app but it is the default so your users would have to go look for the setting and change it for it to behave differently.
MikaelKW 7 Posted February 4, 2025 Author Posted February 4, 2025 5 minutes ago, ebr said: It is not on the login screen in that app but it is the default so your users would have to go look for the setting and change it for it to behave differently. Well, i just tried for the first time on my TV, and for it to stay logged in automatically was not set as default. Not for a friend of mine either when they tried for the first time. Seems strange...
ebr 16336 Posted February 4, 2025 Posted February 4, 2025 1 minute ago, MikaelKW said: and for it to stay logged in automatically was not set as default Exactly what was the option value the first time you entered the setting?
MikaelKW 7 Posted February 4, 2025 Author Posted February 4, 2025 I have no idea how to change the language of the Emby app, so i think the correct translation from Norwegian would be something like: Show login-screen (aka the first option).
Luke 42243 Posted February 4, 2025 Posted February 4, 2025 9 minutes ago, MikaelKW said: I have no idea how to change the language of the Emby app, so i think the correct translation from Norwegian would be something like: Show login-screen (aka the first option). Hi there, have you explored the display settings in the app?
MikaelKW 7 Posted February 4, 2025 Author Posted February 4, 2025 3 minutes ago, Luke said: Hi there, have you explored the display settings in the app? I'll have another look tomorrow. Thanks. 1
ebr 16336 Posted February 5, 2025 Posted February 5, 2025 17 hours ago, MikaelKW said: i think the correct translation from Norwegian would be something like: Show login-screen (aka the first option) The default on a fresh install is definitely the last option "Remember last user" so either that wasn't really a fresh install or the option had been changed. If you didn't actually uninstall the app then previous settings would be maintained.
