Jack Burton 98 Posted February 1, 2025 Posted February 1, 2025 (edited) My Shield (hardwired) has been doing this for quite a while now, Android TV app build 3.4.34 on Windows Beta Server 4.9.0.37 (though it's been happening for the last 20 updates at least). When the next episode of a show starts automatically or next ep is selected, if the video starts right away the audio is offset. Skipping ahead or behind resyncs. Sometimes just skipping starts the audio offset if the show has been playing for multiple episodes (seems to get worse/more frequent the more episodes play). After a few eps of offset audio, the next episode will take a while to start (10-30 seconds) then start 10 or more seconds into the episode, sometimes with the audio fine and others with the audio offset as well as the delay in playing. Included server log, not sure if there's a way to get a Shield log, hoping the server log is enough. Log was sent after an episode auto played and had audio offset. Thanks. Edit: None of these issues occur playing multiple episodes on Google TV embyserver (7).txt Edited February 1, 2025 by Jack Burton
seanbuff 1356 Posted February 1, 2025 Posted February 1, 2025 12 minutes ago, Jack Burton said: Android TV app build 3.4.34 That version number suggests you are using the Emby for Android app, not the Android TV app. 13 minutes ago, Jack Burton said: None of these issues occur playing multiple episodes on Google TV What do you mean by this exactly?
Jack Burton 98 Posted February 1, 2025 Author Posted February 1, 2025 (edited) 14 minutes ago, seanbuff said: Quote That version number suggests you are using the Emby for Android app, not the Android TV app. Correct, I got used to thinking of them as Emby FOR Android TV and Emby Android TV. It is just the Emby Android app Quote What do you mean by this exactly? Episodes play fine on Chromecast for Google TV with the same Android app. Edited February 1, 2025 by Jack Burton
