EmYaj 25 Posted January 30, 2025 Posted January 30, 2025 (edited) I'm getting an issue where some livetv channels are coming up as a black screen. I've confirmed with VLC that the stream works fine, and it's not all channels - just some. I've attached the portion of the log that I thought was most relevant as well as the whole untouched log. The two parts that jumped out at me were: 2025-01-30 11:58:22.003 Info App: Bitrate exceeds DirectStream limit: media bitrate: 8654824, max bitrate: 4000002 (my client was set to Auto but I tried setting it to the Maximum 4K bitrate and the problem persists) and 2025-01-30 11:58:22.005 Info App: ProcessRun 'StreamTranscode e6d43b' Process exited with code 137 - Failed which from a quick google might mean out of memory? I don't believe that is the case but I am on a 8GB RAM server (it doesnt do much else) so I guess it's possible. Usage shows 6GB/8GB (2GB free) in htop. Any suggestions where I might start troubleshooting this? embyserver-fulllog.txt relevant-portion.txt Edited January 30, 2025 by EmYaj
Luke 42241 Posted January 30, 2025 Posted January 30, 2025 Quote 2025-01-30 11:58:22.003 Info App: Bitrate exceeds DirectStream limit: media bitrate: 8654824, max bitrate: 4000002 Hi, this is not an error.
Luke 42241 Posted January 30, 2025 Posted January 30, 2025 Was there an ffmpeg log? Please attach that as well. Thanks.
EmYaj 25 Posted January 30, 2025 Author Posted January 30, 2025 7 minutes ago, Luke said: Hi, this is not an error. OK good to know thank you. 6 minutes ago, Luke said: Was there an ffmpeg log? Please attach that as well. Thanks. Attached two, theyre both from the same similar timestamp and event but I'm not 100% sure which is the one you're looking for. I believe first one (ending 734_1) is correct one. ffmpeg-directstream-b52582b3-6b6e-4d61-ac63-7d8c7563e734_1.txt ffmpeg-directstream-1edd2c69-5514-42b7-91d8-102e27e78988_1.txt
Solution EmYaj 25 Posted February 2, 2025 Author Solution Posted February 2, 2025 Just following up here - I think this may have been a ram issue - I was having this issue a couple of times per day and restarting the server temporarily solved it. I added an additional 8GB ram today (16GB total) and have not had the issue yet today which is much better than the last few days so I suspect the issue may be fixed. I'll continue to monitor and update if this changes but for now if anyone else comes across this - consider adding RAM. 1 1
