rikn78 1 Posted January 30, 2025 Posted January 30, 2025 (edited) I have just upgraded to a fibre connection using a livebox 5. Previously everything was working ok before changing the router. On the server it shows that I am running on http port 8096 and shows remote wan access but no longer shows the local network connection. I have set up port forwarding the same as before but seem to be going in circles. I have checked checked the firewall settings and they are ok. Also used canyouseeme and it does not see port 8096. Any suggestions please? Edited January 30, 2025 by rikn78
Abobader 3484 Posted January 30, 2025 Posted January 30, 2025 Hello rikn78, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution rikn78 1 Posted January 30, 2025 Author Solution Posted January 30, 2025 Solved this by adding IP address to DMZ setting on router.
rbjtech 5335 Posted January 30, 2025 Posted January 30, 2025 14 minutes ago, rikn78 said: Solved this by adding IP address to DMZ setting on router. Likely very unwise as the DMZ zone will be an unfirewalled zone on the router. Yes you will likely have a firewall on the emby 'server' but you really shouldn't put services in the DMZ zone unless you really have to. 2
rikn78 1 Posted February 10, 2025 Author Posted February 10, 2025 Sorry for delay in replying. Removed it from DMZ and magically it suddenly now works. 1
