nt-it-team 6 Posted January 29, 2025 Posted January 29, 2025 Hi all, Using Emby Guide Data it is showing "Sky Q" channel as moved. This is incorrect and needs updating. Data source GBR-1000207-DEFAULT and channel 417 TNTSP3VM This shows the following: This channel is now active again (ignore channel no assigned into the emby TV guide). Online source for TV guide (https://www.sky.com/tv-guide/ - select, Sports for the filter: Can the guide data provided by emby be updated to show the data from the live channel rather than the current info. Hope this gives all the details... Anything further let me know and I can provide. Thank you!
Carlo 4561 Posted January 29, 2025 Posted January 29, 2025 Hi, This is a little bit confusing. 1 hour ago, nt-it-team said: Using Emby Guide Data it is showing "Sky Q" channel as moved. This is incorrect and needs updating. Data source GBR-1000207-DEFAULT and channel 417 TNTSP3VM Are you saying channel 417 is actually Sky Q? 1 hour ago, nt-it-team said: Or are you saying channel 412 is actually Sky Q? As shown in this picture 412 is showing as the TNT Sports 3 channel but your guide as shown above is saying TNT Sports 3 is channel 417 not 412 1 hour ago, nt-it-team said: This channel is now active again (ignore channel no assigned into the emby TV guide). Online source for TV guide (https://www.sky.com/tv-guide/ - select, Sports for the filter: What did you mean by "This channel is now active again (ignore channel no assigned into the emby TV guide)." ? The link for the TV guide you reference doesn't work for me. I'm getting a connection time out trying to get to https://www.sky.com. (maybe this is temporary) For clarity what are you saying should be on Channel 412 & 417? If one of those isn't Sky Q, what channel should it be? For the channels numbers above, what does the current channel lineup say each channel is? Can you show us a screen capture of your channel mapping that include channels 412 & 417.
