Ahole 17 Posted January 29, 2025 Posted January 29, 2025 I made a change in the server cache size and told it to vacuum data upon next start. It would never restart -- found these logs in teh Portainer for the docker Something about shutting down because of "no space left on device" I attached log from portainer I am not a ubuntu expert - I cannot find the actual /config folder for the docker container
Ahole 17 Posted January 29, 2025 Author Posted January 29, 2025 I have looked everywhere for the install and can't find it I was hoping to edit the config file where I change the memory
Luke 42243 Posted January 29, 2025 Posted January 29, 2025 Hi, is any emby server log file generated? Emby Server Data Folder
Ahole 17 Posted January 29, 2025 Author Posted January 29, 2025 That location: Linux /var/lib/emby has no emby folder
Q-Droid 1011 Posted January 29, 2025 Posted January 29, 2025 Where is /config mapped to in portainer for your Emby container?
Ahole 17 Posted January 29, 2025 Author Posted January 29, 2025 6 minutes ago, Q-Droid said: Where is /config mapped to in portainer for your Emby container? volumes: - /docker/emby/config:/config - /mnt/192.168.1.144/CromBackup:/crombackup - /mnt/192.168.1.144/data:/data - /mnt.192.168.1.176/channels-dvr/TV:/channels-dvr But my less than stellar linux knowledge has me unable to find that place ..... ???? on my linux machine
