ginjaninja 605 Posted November 21, 2014 Posted November 21, 2014 (edited) just added forum username to to local account, the logo for user changed to cloud. my roku client now auto logs on ..it makes a bit of sense as the client was configured to use connect. i signed out of mb connect in roku client now i cant get back in, the clients quits when i launch 2014-11-21 00:24:37.5360 Info - App: Udp message sent to 192.168.4.143:56795 2014-11-21 00:24:37.5828 Debug - HttpServer: HTTP GET http://192.168.4.130:8096/mediabrowser/system/info/public?format=json Ip: 192.168.4.143:50302. Headers: User-Agent=Roku/DVP-5.6 (045.06E00060A),Host=192.168.4.130:8096,Accept=*/*,Accept-Encoding=deflate, gzip 2014-11-21 00:24:37.6608 Debug - HttpServer: HTTP Response 200 to 192.168.4.143. Response time: 78.0001 ms. Url: http://192.168.4.130:8096/mediabrowser/system/info/public?format=json 2014-11-21 00:24:37.6920 Debug - HttpServer: HTTP GET http://192.168.4.130:8096/mediabrowser/system/info?format=json Ip: 192.168.4.143:50303. Headers: User-Agent=Roku/DVP-5.6 (045.06E00060A),Host=192.168.4.130:8096,Accept=*/*,Accept-Encoding=deflate, gzip,Content-Type=application/json,X-MediaBrowser-Token=2e941f17be064002bcc1983d2990cd89 2014-11-21 00:24:37.7700 Debug - HttpServer: HTTP Response 200 to 192.168.4.143. Response time: 78.0001 ms. Url: http://192.168.4.130:8096/mediabrowser/system/info?format=json 2014-11-21 00:24:37.7856 Debug - HttpServer: HTTP POST http://192.168.4.130:8096/mediabrowser/Sessions/Capabilities?PlayableMediaTypes=Audio,Video,Photo&SupportedCommands=MoveUp,MoveDown,MoveLeft,MoveRight,Select,Back,GoHome,SendString,GoToSearch,GoToSettings,DisplayContent,SetAudioStreamIndex,SetSubtitleStreamIndex&MessageCallbackUrl=:8324%2Fmediabrowser%2Fmessage Ip: 192.168.4.143:50302. Headers: User-Agent=Roku/DVP-5.6 (045.06E00060A),Host=192.168.4.130:8096,Accept=*/*,Accept-Encoding=deflate, gzip,Authorization=MediaBrowser Client="Roku", Device="Roku 3 (UK)", DeviceId="1WN38M002997", Version="1.72",Content-Length=0,Content-Type=application/x-www-form-urlencoded 2014-11-21 00:24:37.7856 Debug - HttpServer: HTTP Response 204 to 192.168.4.143. Response time: 0 ms. Url: http://192.168.4.130:8096/mediabrowser/Sessions/Capabilities?PlayableMediaTypes=Audio,Video,Photo&SupportedCommands=MoveUp,MoveDown,MoveLeft,MoveRight,Select,Back,GoHome,SendString,GoToSearch,GoToSettings,DisplayContent,SetAudioStreamIndex,SetSubtitleStreamIndex&MessageCallbackUrl=:8324%2Fmediabrowser%2Fmessage 2014-11-21 00:24:37.8324 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 549d75225f83480ca223c42965b57d0e 2014-11-21 00:24:37.8324 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 69baddff72e84e14ae477d133fb57fc1 only solution is 1. quit server 2. launch roku client 3. client presents pin 4. launch server. 5. go to mediabrowser.tv/pin (scan manual just quits client if server is running*) 6. all ok. problems seems 100% reproducible... *strangly if server is kept closed for manual scan,, client sucessfully shows the old server name which is not running. now i can remove the server name... now if i launch server and restart client the client seems to reaquire server (not via connect) and work normally...woulgave expected to have had to reaquire server.by connect pin or scan. so very screwed up behaviour after signing out of mbconnect... Edited November 21, 2014 by ginjaninja 1
ginjaninja 605 Posted November 22, 2014 Author Posted November 22, 2014 (edited) V1.73 has fixed immediate crash as i play about with signin in and disconnecting with mbconnect and local connect. A bit of user feedback...the change server workflows still feels a little screwy... If you signout of mbconnect..restart client.. (connect locally)...change server..remove local server.... A. Back button still works and takes you back to the connection..perhaps it shouldnt...if there is no server connection perhaps back (and all routes) should go to connection screen. B. Indeed if you restart client..i find i am still connected to local server as shown by its users appearing and if i choose select server...my local server still shows and i cant remove... Given both the scan and mbconnect functions work forward...perhaps the client can afford to really let go of connections..safe in the knowledge the user can recconect when they want.. Edited November 22, 2014 by ginjaninja
