Rob_1969 13 Posted January 25, 2025 Posted January 25, 2025 hello everyone windows 11 i mostly use my Theatre on my tv app however today i attempted to use it on my pc linked to my tv, so i sometimes use 2 screens, i opened theatre and then minimized it, i could not maximize it again, nothing seemed to work to get it back again so i uninstalled it again, now im trying to install it and it has hidden the window again while im trying to install it, see pic. any ideas what it could be guys.
softworkz 5133 Posted January 25, 2025 Posted January 25, 2025 Seems to be the same as this: Are you able to PM me the settings.dat?
Rob_1969 13 Posted January 25, 2025 Author Posted January 25, 2025 12 minutes ago, softworkz said: Are you able to PM me the settings.dat? No sorry because repeated attempts to reinstall did not work, during uninstall i cleared the cache files and settings etc hoping it would help. I seen in other posts someone reinstalled it to fix it however that did not work for me. 1
Rob_1969 13 Posted January 26, 2025 Author Posted January 26, 2025 I managed to reinstall Theatre today however I did not do anything specific. I was messing about with different things. I installed displayfusion too to manage dual monitors, cheers.
softworkz 5133 Posted February 11, 2025 Posted February 11, 2025 There's an fix attempt in 2.216.0. Should you see this issue again, please try with that (or a later) version once it's released. Thanks a lot for reporting!
Rob_1969 13 Posted February 12, 2025 Author Posted February 12, 2025 9 hours ago, softworkz said: There's an fix attempt in 2.216.0. Should you see this issue again, please try with that (or a later) version once it's released. Thanks a lot for reporting! many thanks for letting me know.
