Peter Nent 71 Posted January 24, 2025 Posted January 24, 2025 Like to get an idea when the issues with Remote Control (RC) are beeing addressed and solved in the Emby for Windows en Xbox client? (and afterwards also the Emby WMC client ?) Thanks & best regards, Peter
Luke 42233 Posted January 25, 2025 Posted January 25, 2025 Hi there, what issue are you referring to?
MikeB111 60 Posted January 25, 2025 Posted January 25, 2025 Not sure what the original poster was specifically concerned with, but how about this one: And this one: Thanks!
Peter Nent 71 Posted January 26, 2025 Author Posted January 26, 2025 I'm using the new Emby Windows v2.211.2.0 and I'm using the original Microsoft RC, but several buttons don't function as they used to do in MCE and should do now as is explained in several postings of several users. Some examples: When looking Live-TV, the buttons channel-+/- don't functions, nor do the nummerical nummers: 0 until 9 work... When the EPG button is pressed, the EPG appeares, but doesn't disappear after pressing any other button there after When the info button is pressed, the info appeares, but also doesn't go away In general: after leaving (for example) live-TV (or Movies or...), back to the main menu, the RC-position is set to the default position (upper left), in stead of returning back to the last choosen position, making manouvering far more easier. Etc. Please test it also yourselves and make using an RC with EMBY attractive again (if it helps you: try to let it work as it used to do in the original MCE). Thanks & best regards, Peter
Peter Nent 71 Posted January 26, 2025 Author Posted January 26, 2025 (edited) On 1/25/2025 at 5:43 AM, Luke said: Hi there, what issue are you referring to? Thanks & best regards, Peter Edited January 26, 2025 by Peter Nent
softworkz 5133 Posted January 26, 2025 Posted January 26, 2025 Update for Xbox The new Xbox beta 2.212.0 (due in a few hours) will fix RC issues in the Xbox app. 2
softworkz 5133 Posted February 11, 2025 Posted February 11, 2025 On 1/26/2025 at 1:38 PM, Peter Nent said: I'm using the new Emby Windows v2.211.2.0 and I'm using the original Microsoft RC, but several buttons don't function as they used to do in MCE and should do now as is explained in several postings of several users. Some examples: When looking Live-TV, the buttons channel-+/- don't functions, nor do the nummerical nummers: 0 until 9 work... When the EPG button is pressed, the EPG appeares, but doesn't disappear after pressing any other button there after When the info button is pressed, the info appeares, but also doesn't go away In general: after leaving (for example) live-TV (or Movies or...), back to the main menu, the RC-position is set to the default position (upper left), in stead of returning back to the last choosen position, making manouvering far more easier. Etc. Please test it also yourselves and make using an RC with EMBY attractive again (if it helps you: try to let it work as it used to do in the original MCE). Those are all things for @Luketo get right at the side of the core application code. The Windows app is sending the correct button codes but the core app doesn't do the right things with those inputs. Thanks
AxeMan 25 Posted February 17, 2025 Posted February 17, 2025 Something I noticed is that when you are viewing a collection - you can't select an individual movie in the collection. I end up grabbing my keyboard/mouse and moving to the movie I want to watch.
