linexis26 1 Posted January 24, 2025 Posted January 24, 2025 Hi, Im frustrated All 4K Remux start stuttering after a few Seconds/Minutes. Everything is direct Play, with wired AP 1GBit Connection Server is an Win 11, i5 13400 with Onboard GPU Intel UHD 730 Files are Local on Server. Ive tried all Sound Formats, with/without Subtitles.... Fire TV Emby App, Android TV Emby App.... all Stuttering. my HATE Test movie is Super Mario Bros Movie. Every Time after 1min 30 sec when the Lava falls, stuttering... I posted some logs Pls what can I do else? embyserver.txt ffmpeg-remux-bbd55b57-10fc-4bb3-9887-e33be4421268_1.txt
Solution ebr 16336 Posted January 24, 2025 Solution Posted January 24, 2025 Hi. Your example is not direct playing. It is remuxing due to some sort of error attempting to direct play. The first thing I would try is the standard Android app. Search for it in the store. 1
linexis26 1 Posted January 25, 2025 Author Posted January 25, 2025 OMG you made my day I tried another Version and this one is working flawlessly. Very nice. Only thing now is: Can I change the start Page? So i can select user? But I LOVE YOU Thank you
Luke 42243 Posted January 30, 2025 Posted January 30, 2025 On 1/24/2025 at 11:14 PM, linexis26 said: OMG you made my day I tried another Version and this one is working flawlessly. Very nice. Only thing now is: Can I change the start Page? So i can select user? But I LOVE YOU Thank you HI, how have you configured your logon options in the app?
linexis26 1 Posted January 31, 2025 Author Posted January 31, 2025 where i can find the logon option in android app? i found it only in android for fire tv
linexis26 1 Posted January 31, 2025 Author Posted January 31, 2025 Ah i found it. Uncheck remember me... Now user selection is the start screen. But I always have to type in my password.
Luke 42243 Posted January 31, 2025 Posted January 31, 2025 1 hour ago, linexis26 said: Ah i found it. Uncheck remember me... Now user selection is the start screen. But I always have to type in my password. Hi, have you checked out the profile pin feature ? You can configure this in the same place you configure your password for the server. This will allow you to get back in quicker. 1
linexis26 1 Posted February 1, 2025 Author Posted February 1, 2025 (edited) Solution for me: My username was the only one with password (adminuser). Now, no more Password on my username, but I checked no more remote connection for adminuser. Im allways connected to my Homerouter via VPN. So i can still change and watch from anywhere Edited February 1, 2025 by linexis26 1
