sidkipper 1 Posted January 23, 2025 Posted January 23, 2025 Whenever I query the LiveTv/Recordings/Series endpoint I get no results, have tried supplying UserId or SeriesId as a parameter - what's required to get results back from this endpoint? Saw that UserId is required for LiveTv/Recordings, and can get results back from that, but would prefer to work with Series rather than individual Recordings if possible. $res = Invoke-RestMethod -Uri "http://$url/LiveTv/Recordings/Series?UserId=$userId&api_key=$embyToken" $res.Items.count 0 $res = Invoke-RestMethod -Uri "http://$url/LiveTv/Recordings?UserId=$userId&api_key=$embyToken" $res.Items.count 556
Luke 42233 Posted January 23, 2025 Posted January 23, 2025 Hi, does the recordings tab under Live TV in the web app show data for you?
sidkipper 1 Posted January 24, 2025 Author Posted January 24, 2025 Yes the recordings are visible via the Live TV Recordings tab
Luke 42233 Posted January 25, 2025 Posted January 25, 2025 OK. The easiest way to learn would be to open the browser debugger and monitor the network request after clicking into the Recordings tab.
sidkipper 1 Posted January 25, 2025 Author Posted January 25, 2025 Thanks for the pointer to use browser dev view. Couldn't find any examples of the /LiveTv/Recordings/Series endpoint being used, but can get Series data back using /LiveTv/SeriesTimers, which should give me enough to be able to manage the space used by my family recording too much and filling the storage up. 1
