vincen 72 Posted February 17, 2025 Author Posted February 17, 2025 19 minutes ago, Luke said: There isn't really a definitive standard or non-standard embedded tag. For the best results with as many applications as possible, you should use tagging software that can write to all of them. Thanks for confirmation and I confirm ! All tracks I have been able to fully edit all tags are showing up perfectly well in Emby. Unhappy only software I have found so far in Linux that is able to do that is Musicbrainz Picard 1
