PuffyToesToo 348 Posted January 20, 2025 Posted January 20, 2025 The drag and drop function in library ordering per user is a wonderful thing, and I do thank you for adding that at one point. I have great difficulty "grabbing" each item to reorder them, however. Is there something I am missing, or can you make them easier to grab? Thank you.
Happy2Play 9814 Posted January 20, 2025 Posted January 20, 2025 Probably need more specific information on what client and or specific browser you are having this issue in. As with a mouse it is pretty easy to just click and drag. But yes if I actually slide left to right during the click it will no longer allow up and down order change. (Edge)
