mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 @Gilgamesh_48 thanks for honest answer. i try fix my emby agin delate all files and everything and start agin to install,
pwhodges 2039 Posted January 20, 2025 Posted January 20, 2025 7 hours ago, mrdino87 said: i download nordvpn tomrow its night here in sweden i am realy tired. NordVPN is not in any way related to your problem; it is never necessary, and only of possible interest when you have remote connections. Installing it without knowing what it can do for you will only cause confusion. You've been told that the problem is likely down to your going back a version. Either reinstall the current beta and take it from there, or wipe the installation and reinstall the stable version. If you then still have a problem accessing Emby on localhost, then we have a better chance of fixing it. Paul 2
Luke 42289 Posted January 20, 2025 Posted January 20, 2025 Yes if you want back from 4.9 to 4.8 then that is not supported. You need to either make a fresh start with 4.8, or stay on 4.9.
mrdino87 0 Posted January 23, 2025 Author Posted January 23, 2025 nothing have work for me still not connect, how can i download older version of emby?
Happy2Play 9814 Posted January 23, 2025 Posted January 23, 2025 41 minutes ago, mrdino87 said: nothing have work for me still not connect, how can i download older version of emby? A new server log for one. But as mentioned you cannot go to an older version unless you delete the database as it is not compatible. I still do not see how any of the nordvpn/meshnet has any relevance here. 1
sa2000 703 Posted January 24, 2025 Posted January 24, 2025 @mrdino87Just to make sure you know what you need to delete to start afresh and get rid of the beta database and associated data: 1. In Windows Task Manager - check that EmbyServer process is not running. If you see it, right click on it and select End Task 2. When you no longer see EmbyServer in Windows Task Manager, delete this folder C:\Users\walle\AppData\Roaming\Emby-Server 3. Download Emby Server 4.8.10.0 from here 4. Open the downloaded Setup exe file After the install the browser should open by default to go through server setup 1
mrdino87 0 Posted January 24, 2025 Author Posted January 24, 2025 @Tech-Support now my default webb browser olny loading not come to set up server hm
Happy2Play 9814 Posted January 24, 2025 Posted January 24, 2025 1 minute ago, mrdino87 said: @Tech-Support now my default webb browser olny loading not come to set up server hm What exactly to you see? I am confused here as every possible step to fix your issue has been mentioned. Please provide server logs and everything you have done.
mrdino87 0 Posted January 24, 2025 Author Posted January 24, 2025 @Tech-Support now my default webb browser olny loading not come to set up server hm the webb site browser say "the site The website cannot be accessed "
mrdino87 0 Posted January 24, 2025 Author Posted January 24, 2025 how can i find server logg agin dont remember?
Happy2Play 9814 Posted January 24, 2025 Posted January 24, 2025 3 minutes ago, mrdino87 said: @Tech-Support now my default webb browser olny loading not come to set up server hm the webb site browser say "the site The website cannot be accessed " I don't now how to get that unless there are other translations. But suggest Emby is not running. Does EmbyServer.exe show running it task manager? 1 minute ago, mrdino87 said: how can i find server logg agin dont remember? C:\Users\walle\AppData\Roaming\Emby-Server\programdata\logs
mrdino87 0 Posted January 24, 2025 Author Posted January 24, 2025 cant find the emby server mapp in appdata annymore dont know why hm
Happy2Play 9814 Posted January 24, 2025 Posted January 24, 2025 5 minutes ago, mrdino87 said: cant find the emby server mapp in appdata annymore dont know why hm It is a hidden folder if you have not enable show hidden folders, but assuming you are using the same user as previous logs you should be able to copy and paste that path in explorer.
mrdino87 0 Posted January 24, 2025 Author Posted January 24, 2025 i give up i buy nas server and start on other system thanks everybody i give up realy
