mrdino87 0 Posted January 20, 2025 Posted January 20, 2025 Hi people i have problem to acess my local host and even local ip number i cant sign in to my server. its say" invalid request" next problem my remote adress not working anny more dont know how to fix all my problems my port its closed dont know how to fix this somebody help me plz? somebody use teamview or something to help me. i am not so good on this shiet!
Abobader 3491 Posted January 20, 2025 Posted January 20, 2025 Hello mrdino87, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42289 Posted January 20, 2025 Posted January 20, 2025 Quote Hi people i have problem to acess my local host and even local ip number i cant sign in to my server. its say" invalid request" Hi there, what address is in the browser address bar?
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 http://localhost:8096/web/index.html nothing work anny more i have 2 problems
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 that adress you mean? i cant reach my server nothing work hm
Luke 42289 Posted January 20, 2025 Posted January 20, 2025 26 minutes ago, mrdino87 said: http://localhost:8096/web/index.html nothing work anny more i have 2 problems is Emby Server running when you try to access it? Please attach the emby server log: How to Report a Problem Thanks.
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 i cant acess my server logg you mean on my windows appdata? i try to reinstall emby but still dont work, looks like i dont have emby on on computer but i have emby running in the background the server i will try to find server logg
Happy2Play 9814 Posted January 20, 2025 Posted January 20, 2025 This here tells us you were on beta and reverted to release. 2025-01-20 02:00:00.037 Error TaskManager: Error *** Error Report *** Version: 4.8.10.0 Command line: C:\Users\walle\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.22631 Framework: .NET 6.0.33 OS/Process: x64/x64 Runtime: C:/Users/walle/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 16 Data path: C:\Users\walle\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\walle\AppData\Roaming\Emby-Server\system SQLitePCL.pretty.SQLiteException: Error: no such column: A.Album - select A.type,A.Id,A.StartDate,A.EndDate,A.IsMovie,A.IsSeries,A.IsKids,A.IsSports,A.IsNews,A.IsRepeat,A.IsNew,A.IsPremiere,A.IsLive,A.CommunityRating,A.CustomRating,A.IndexNumber,A.IsLocked,A.PreferredMetadataLanguage,A.PreferredMetadataCountryCode,A.Width,A.Height,A.DateLastRefreshed,A.Name,A.Path,A.PremiereDate,A.Overview,A.ParentIndexNumber,A.ProductionYear,A.OfficialRating,A.SortName,A.RunTimeTicks,A.Size,A.Container,A.DateCreated,A.DateModified,A.guid,A.ParentId,A.DateLastSaved,A.LockedFields,A.OriginalTitle,A.CriticRating,A.SeriesName,A.Album,A.AlbumId,A.SeriesId,A.PresentationUniqueKey,A.Tagline,A.ProviderIds,A.Images,A.ProductionLocations,A.TotalBitrate,A.ExtraType,A.ExternalId,A.SeriesPresentationUniqueKey,A.Status,A.DisplayOrder,A.ThreeDFormat,A.ChannelNumber,A.RemoteTrailers,A.SortIndexNumber,A.SortParentIndexNumber,A.IndexNumberEnd,A.IsPublic from MediaItems A where A.Type in (1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,18,19,20,21,22,23,24,25,26,27,28,29,31,34) AND A.ParentId=1 AND A.ExtraType is null SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteDatabaseConnection.PrepareStatement(String sql, ReadOnlySpan`1& tail) at SQLitePCL.pretty.DatabaseConnection.PrepareStatement(IDatabaseConnection This, String sql) at Emby.Sqlite.BaseSqliteRepository.PrepareStatement(IDatabaseConnection connection, String sql) at Emby.Server.Implementations.Data.SqliteItemRepository.QueryItemsInTransaction[T](InternalItemsQuery query, IDatabaseConnection db, String[] columnsToSelect, Boolean filterColumns, String[] groupBy, Func`5 rowReaderFn, String methodName) at Emby.Server.Implementations.Data.SqliteItemRepository.GetItemList(InternalItemsQuery query) at Emby.Server.Implementations.Library.LibraryManager.GetItemsResult(InternalItemsQuery query) at MediaBrowser.Controller.Entities.Folder.GetItemsInternal(InternalItemsQuery query) at MediaBrowser.Controller.Entities.AggregateFolder.GetItemsInternal(InternalItemsQuery query) at MediaBrowser.Controller.Entities.Folder.GetItems(InternalItemsQuery query) at MediaBrowser.Controller.Entities.Folder.GetChildren(InternalItemsQuery query) at Emby.Providers.MediaInfo.ChapterImagesTask.GetAllItemIdsToRefresh(Boolean extractImages) at Emby.Providers.MediaInfo.ChapterImagesTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: SQLitePCL.pretty TargetSite: SQLitePCL.pretty.IStatement PrepareStatement(System.String, System.ReadOnlySpan`1[System.Byte] ByRef) You can not downgrade without starting over do to database changes. So your options are reinstall 4.9.0.35 or delete the database and start over.
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 that i have try to do reinstall emby server still same problem where can i find the old verison reinstall 4.9.0.35? i link my other files server-install.log embyserver.txt
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 can somebody help me via teamview? or something i am realy bad on this. i cant connect on anny device i cant even logg in to my local host server its say invalid request" and when it work before i cant acess to my remote adress, my friends cant watch movie on the remote adress they cant acess. But point is i cant reach "connect to my local host on emby. other problem i know my port 8096 its closed some how? dont know why can somebody here port forwarding via teamview?
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 i have reboot my computer so many times. i try to install the old 4.9.0.35 ia have still same problem invalid request"
Happy2Play 9814 Posted January 20, 2025 Posted January 20, 2025 (edited) 14 minutes ago, mrdino87 said: that i have try to do reinstall emby server still same problem where can i find the old verison reinstall 4.9.0.35? You can't just reinstall unless you fully uninstall to downgrade from beta. You can get the beta installer on download page. Emby Server for Windows or you can get the zip from github and rename and replace the system folder. Release 4.9.0.35-beta · MediaBrowser/Emby.Releases Edited January 20, 2025 by Happy2Play
Happy2Play 9814 Posted January 20, 2025 Posted January 20, 2025 Just now, mrdino87 said: i have reboot my computer so many times. i try to install the old 4.9.0.35 ia have still same problem invalid request" Need to see a server log from this.
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 @SunD0wni found my ip adress on cmd yes? @Happy2Play you need to scroll up in the forum you will see the 2 server logs.
Happy2Play 9814 Posted January 20, 2025 Posted January 20, 2025 4 minutes ago, mrdino87 said: @Happy2Play you need to scroll up in the forum you will see the 2 server logs. That log is 4.8.10.0 also.
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 @SunD0wni dont acting fool i olny dont understand all of this so much but i can try to dwonload nordvpn and install nordvpn how can i enable meshnet? my emby server cant even open up invalid request" its say i dont come to dashboard
Happy2Play 9814 Posted January 20, 2025 Posted January 20, 2025 I would not install anything, but we need to see your server log from beta install as the previous logs show a database that will not work with 4.8.10.0.
Gilgamesh_48 1244 Posted January 20, 2025 Posted January 20, 2025 Since the install appears to be all screwed up I believe you need to first full uninstall Emby and be sure to check "Remove all traces" then reinstall Emby and set up everything again. There is another way: You probably need to eliminate all references to your current install and, if the "remove all traces" does not really work, you can delete everything manually. I do not remember offhand the directory names but I am quite sure you can find them in the various documentation. Just get rid of all your Emby install, you can leave the media alone as that does not matter, and be sure to remove all Emby's support directories, I think you'll fid them all under the primary user's directory.
Happy2Play 9814 Posted January 20, 2025 Posted January 20, 2025 Yep removing all traces will delete C:\Users\walle\AppData\Roaming\Emby-Server\programdata and have you start over fresh. I guess you can test by ensuring Emby is not running via task manager, go to C:\Users\walle\AppData\Roaming\Emby-Server\programdata\data\library.db and renaming and launching Emby to see if you still have a issue if you are not going to revert back to 4.9.0.35.
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 i download nordvpn tomrow its night here in sweden i am realy tired.
mrdino87 0 Posted January 20, 2025 Author Posted January 20, 2025 its nordvpn free program ? i will try to download nordvpn for free than
Gilgamesh_48 1244 Posted January 20, 2025 Posted January 20, 2025 I strongly suggest you do not use NordVPN as it has been reported that it has leaks and does not protect user data very well. Some have had good luck with it but it is free and so many "free" products have built in problems. This is a case of "You get what you pay for." But do as you wish and if the danger is not important to you then go ahead.
