SShzin 32 Posted February 22, 2025 Author Posted February 22, 2025 Is there any movement on releasing updated apps? This is still an issue.
Luke 42176 Posted February 22, 2025 Posted February 22, 2025 The iOS update is out. We are working hard on the others. Thanks. 1
SShzin 32 Posted February 27, 2025 Author Posted February 27, 2025 (edited) Was able to get my hands on a ios device (ipad) and can confirm latest update the issue is fixed. Please release a stable (non beta) android TV and universal android app update. I see there have been a couple updated beta releases since this was figured out, please release the updated stable versions. Edited February 27, 2025 by SShzin 1
SShzin 32 Posted March 8, 2025 Author Posted March 8, 2025 Any update on this? @Luke@sa2000 According to the update post, Android devices haven't been updates since last year. Quote Emby for Android TV Google Devices Stable: v2.1.23 (2024/12/27) Beta: v2.1.26 (2025/02/13) Amazon Devices Stable: v2.1.23 (2024/12/27) Beta: v2.1.26 (2025/02/13) Stable Release Notes Beta Release Notes Universal Emby for Android Stable: v3.4.20 (2024/10/12) Release Notes Beta: v3.4.46 (2025/03/07)
SShzin 32 Posted March 8, 2025 Author Posted March 8, 2025 2 hours ago, Luke said: If you need immediate relief: I would rather not install the beta, as there may be more bugs or issues to contend with than what I've posted here. Any update as to when we should see a stable version update? Thanks.
Luke 42176 Posted March 8, 2025 Posted March 8, 2025 I don't have an ETA but likely in the near future. 1
SShzin 32 Posted April 3, 2025 Author Posted April 3, 2025 On 3/8/2025 at 5:31 PM, Luke said: I don't have an ETA but likely in the near future. @LukeHello, this is almost a month out now, could I have an update on when Android app updates, etc ,should be coming out?
Luke 42176 Posted April 3, 2025 Posted April 3, 2025 Hi, we should have an update in the store soon. Thanks,. 1
SShzin 32 Posted May 3, 2025 Author Posted May 3, 2025 @Lukeanother month by, any update on a release? Thanks.
SShzin 32 Posted May 3, 2025 Author Posted May 3, 2025 2 hours ago, Luke said: Hi, what Emby app version are you on now? Latest on Android and Android TV
SShzin 32 Posted May 4, 2025 Author Posted May 4, 2025 Okay just saw that Android was updated on April 29th, will update. Android TV Versions is 2.1.23g
SShzin 32 Posted May 4, 2025 Author Posted May 4, 2025 (edited) I've been going off of this missed the Android update. Thanks. Any update on the Android TV version? Edited May 4, 2025 by SShzin
Solution Luke 42176 Posted May 4, 2025 Solution Posted May 4, 2025 1 hour ago, SShzin said: I've been going off of this missed the Android update. Thanks. Any update on the Android TV version? Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
SShzin 32 Posted May 11, 2025 Author Posted May 11, 2025 Confirm fixed and working correctly on latest Emby for Android. Thanks! 1 1
