sa2000 700 Posted February 3, 2025 Posted February 3, 2025 @tanStaaflfor the mkv media files giving no compatible streams, I would need actual examples. Confirmation that it is still happening. and emby server logs covering the time of the error and details of what media files
sa2000 700 Posted February 3, 2025 Posted February 3, 2025 @SShzinSorry my earlier comment was wrong. I deleted it. I will split the collections issue into a separate topic
SShzin 33 Posted February 3, 2025 Author Posted February 3, 2025 Thank you, was there any update on the issue sent to the dev team?
sa2000 700 Posted February 4, 2025 Posted February 4, 2025 12 hours ago, SShzin said: Was there any update on the issue sent to the dev team It is being looked into. I have reproduced the error on 4.9.0.37 1
sa2000 700 Posted February 5, 2025 Posted February 5, 2025 On 03/02/2025 at 21:56, SShzin said: Thank you, was there any update on the issue sent to the dev team? Planning for fix in beta 4.9.0.38. Let me know the outcome once 4.9.0.38 is available Thanks 1
SShzin 33 Posted February 6, 2025 Author Posted February 6, 2025 Quote Let me know the outcome once 4.9.0.38 is available Absolutely will do.
SShzin 33 Posted February 6, 2025 Author Posted February 6, 2025 Quote Planning for fix in beta 4.9.0.38 Will there be a update for the stable version as well as beta? I'd like to (if possible) stay on stable.
sa2000 700 Posted February 6, 2025 Posted February 6, 2025 7 minutes ago, SShzin said: Will there be a update for the stable version as well as beta? Lets wait for 4.9.0.38 to come out and the fix is confirmed and then we can see if it can be released into the stable release. Otherwise would need to wait for 4.9.0.xx to get released as the next stable release 1
SShzin 33 Posted February 7, 2025 Author Posted February 7, 2025 @sa2000Testing .38 now, I think this fixed it but I want to make 100% sure so I'm going to use it for a day or two to confirm. Let me know what you see on your end.
SShzin 33 Posted February 8, 2025 Author Posted February 8, 2025 (edited) Okay it seems to fix it for browser *ONLY*. Devices are still getting the error. I'm guessing the apps still need an update possibly? If you are on the direct URL, it works, but if you try to use it via any app or app.emby.media it does not work. So unfortunately this update didn't fix it. Edited February 8, 2025 by SShzin
SShzin 33 Posted February 8, 2025 Author Posted February 8, 2025 Couldn't edit again, but app.emby.media does work. Apps still have the error.
sa2000 700 Posted February 8, 2025 Posted February 8, 2025 (edited) 13 hours ago, SShzin said: If you are on the direct URL, it works, but if you try to use it via any app or app.emby.media it does not work. So unfortunately this update didn't fix it. So it appears to have required client app fix - with it being fixed in the Emby Web app bundled with server beta 4.9.0.38, as well as the hosted app available at https://app.emby.media and http://app.emby.media Can you tell me which client apps you use that are exhibiting the problem Edited February 8, 2025 by sa2000
SShzin 33 Posted February 8, 2025 Author Posted February 8, 2025 (edited) Quote Can you tell me which client apps you use that are exhibiting the problem Yes, Android, Android TV and Apple TV. I don't have any other devices, so those are the only ones I'm aware of right now. It's possible that other devices are affected. To be clear, this is still affecting the stable version. Edited February 8, 2025 by SShzin
sa2000 700 Posted February 8, 2025 Posted February 8, 2025 3 hours ago, SShzin said: this is still affecting the stable version. Is this also the case with the app.emby.media ?
SShzin 33 Posted February 8, 2025 Author Posted February 8, 2025 31 minutes ago, sa2000 said: Is this also the case with the app.emby.media ? Yes, correct.
sa2000 700 Posted February 8, 2025 Posted February 8, 2025 6 minutes ago, SShzin said: Yes, correct. So Emby Web on app.emby.media works ok on 4.9.0.38 but not 4.8.10.0 ?
SShzin 33 Posted February 8, 2025 Author Posted February 8, 2025 Just tested again, looks like I'm wrong on that one. Apologies. app.emby.media seems that it's working on both stable and beta. Not working on the above mentioned apps.
sa2000 700 Posted February 8, 2025 Posted February 8, 2025 3 minutes ago, SShzin said: Apologies. app.emby.media seems that it's working on both stable and beta. Ok - so that indicates it was a client app issue 1
SShzin 33 Posted February 8, 2025 Author Posted February 8, 2025 (edited) 2 minutes ago, sa2000 said: Ok - so that indicates it was a client app issue Good to know, but it's not working on the direct web URL of the stable server. So the apps need an update I'm guessing? Edited February 8, 2025 by SShzin
sa2000 700 Posted February 8, 2025 Posted February 8, 2025 (edited) 23 minutes ago, SShzin said: So the apps need an update I'm guessing I believe so. I have passed the feedback to the development team. The direct url access is using the Emby Web app version that is bundled with the server software - so on Emby Server 4.8.10.0 there would not be a fix. The hosted web app on app.emby.media appears to have the fix that went into the bundled Emby Web app in Emby Server beta 4.9.0.38 Edited February 8, 2025 by sa2000 1
SShzin 33 Posted February 8, 2025 Author Posted February 8, 2025 If you need anything else from me, I'm available for additional testing. Quote so on 4.8.10.0 there would not be a fix. Agreed, that there is no reason for a fix when app.emby.media is providing the fix currently for web users. 1
SShzin 33 Posted February 9, 2025 Author Posted February 9, 2025 Quote I believe so. I have passed the feedback to the development team. Is this the best place to check for updates? https://emby.media/community/index.php?/topic/21348-emby-latest-versions/
sa2000 700 Posted February 10, 2025 Posted February 10, 2025 13 hours ago, SShzin said: Is this the best place to check for updates? https://emby.media/community/index.php?/topic/21348-emby-latest-versions/ Yes - it is. It does include betas as well 1
SShzin 33 Posted February 14, 2025 Author Posted February 14, 2025 On 2/10/2025 at 5:15 AM, sa2000 said: Yes - it is. It does include betas as well @sa2000I don't mind using beta server if needed, but I'd rather not use the beta app on my devices. Are you able to test if the beta works for this? I see the universal was released on the 11th.
Luke 42276 Posted February 14, 2025 Posted February 14, 2025 Hi, it will be in the next update of each Emby app that is impacted. Thanks. 2
