Revenent 15 Posted January 19, 2025 Posted January 19, 2025 Really niche ask, but would it be hard to enable multi-view compatibility for the Emby app? Basically have the ability to mirror the phone while using Emby.
Luke 42239 Posted January 19, 2025 Posted January 19, 2025 Hi, so you want to see and phone screen on the TV?
Revenent 15 Posted January 19, 2025 Author Posted January 19, 2025 Your response seems to be a bit garbled, so not completely sure what it means. But for example, on my QN90D, I can mirror the phone and run the YouTube app at the same time in a side-by-side mode.
Luke 42239 Posted January 20, 2025 Posted January 20, 2025 Ah I see what you mean. Yes it makes sense to support this.
