HaoGe818 0 Posted January 15, 2025 Posted January 15, 2025 Hi there, I found that the audio and video info for the movie annd show I added is not swing up. I can’t found the issue. I tried to add a new one and so I can have a log uploaded. Please help me check it. Thanks! embyserver.txt
visproduction 335 Posted January 15, 2025 Posted January 15, 2025 Do you have a copy of Hao dong xi (2024)? Try using Settings ... 3 dots / Identity / IMDB / And enter: tt31807233 The search for the media name in Chinese is perhaps not being found. Hope that helps.
HaoGe818 0 Posted January 15, 2025 Author Posted January 15, 2025 Sorry, what I mean is my Emby is not showing each videos format like 1080 HEVC, is not showing the audio format. and I don’t think I have Hao Dong Xi?
HaoGe818 0 Posted January 15, 2025 Author Posted January 15, 2025 1 hour ago, visproduction said: Do you have a copy of Hao dong xi (2024)? Try using Settings ... 3 dots / Identity / IMDB / And enter: tt31807233 The search for the media name in Chinese is perhaps not being found. Hope that helps. Sorry for the misleading title. The problem is I can’t see the video info and audio info. Such as 1080 hevc, mbps, audio format and so on
Luke 42243 Posted January 15, 2025 Posted January 15, 2025 Hi, this information is currently not extracted from iso files. Have you considered converting to mkv using make mkv?
HaoGe818 0 Posted January 15, 2025 Author Posted January 15, 2025 1 minute ago, Luke said: Hi, this information is currently not extracted from iso files. Have you considered converting to mkv using make mkv? Hi I tried to add a mkv, and it’s still not working
Solution Luke 42243 Posted January 15, 2025 Solution Posted January 15, 2025 Hi, the server doesn't probe strm files for media info.
