Fch11 3 Posted January 14, 2025 Posted January 14, 2025 This is using the emby for fire tv app but regular emby app on appstore has the same issue. I can't get DTS to play direct on this device without video stuttering/AV sync issues. But works fine when I disable DTS on emby settings where it just says software decode. I'm using this sound bar Fire TV Soundbar Plus | Amazon error happens with or without it. Video works fine with dts directly with emby theater on my computer so it's not my video. Cube is connected to wifi. 2.4ghz/5ghz makes no difference. Logs show which first playback was on computer, 2nd on emby for fire tv. embyserver.txt
Fch11 3 Posted January 15, 2025 Author Posted January 15, 2025 I tried on plex and no video audio issues same file.
Fch11 3 Posted January 15, 2025 Author Posted January 15, 2025 It only has .srt so if they were i had that on. I just tested it with them off right now and same issue. When i played the secondary ac3 commentary audio it plays fine.
Luke 42243 Posted January 17, 2025 Posted January 17, 2025 @Fch11 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
Fch11 3 Posted January 17, 2025 Author Posted January 17, 2025 23 minutes ago, Luke said: @Fch11 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. Same issue, video freezing audio is desynced. It's not really usable since i can't disable dts passthrough on this version through playback settings. embyserver.txt
Fch11 3 Posted January 21, 2025 Author Posted January 21, 2025 @Luke Thanks, I also have a problem with overlayed .ass subtitles not showing up for anime too. The ones that replace signs/text from japanese with english or puts english text on top of them. Not just a text at the bottom like a regular subtitle. Windows store emby and ipad emby work good with those forced .ass subtitles tho. This is with the emby for fire tv since i can't use the other android app because i can't disable dts passthrough to fix audio/stutter. Plx is also showing the same .ass subtitle track correctly and how the other emby apps are.
Fch11 3 Posted January 21, 2025 Author Posted January 21, 2025 Edit: This seems to be a fire tv cube 3rd gen issue. I swapped a fire tv 4k max and all the issues were fixed. Direct passthrough dts and the .ass subtitle issue.
Luke 42243 Posted January 19 Posted January 19 For video stuttering, please try Emby for Android 3.5.25 and let us know how that compares: https://emby.media/emby-for-android.html Thanks.
