GauntFeatures 1 Posted January 14, 2025 Posted January 14, 2025 Hi. I am having great difficulty getting anything to play. Constantly getting no compatible streams error. My setup is external hard drive attached to router and Emby server on my laptop. I have set the hard drive as network folder on my laptop. I can access this and moves files without problem. Sometimes movies play and sometimes the same movies don't play. I think i have setup everything up correctly and have not changed any settings from the default settings. Log shows error reading header but i'm clueless as to what that means. I have attached log. Can anyone help with this. Thanks for any help you can provide. ffmpeg-transcode-d9a1040b-cbb4-42f0-a36c-8b4d1c6eea4f_1.txt
Abobader 3484 Posted January 14, 2025 Posted January 14, 2025 Hello GauntFeatures, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42181 Posted January 14, 2025 Posted January 14, 2025 Hi there, please attach the main Emby server log as well. Thanks.
GauntFeatures 1 Posted January 14, 2025 Author Posted January 14, 2025 Hi is this the one?? embyserver.txt
Lessaj 477 Posted January 14, 2025 Posted January 14, 2025 (edited) I don't think your SMB path is available so it's failing to open the file. Quote 2025-01-14 18:59:06.932 Error LibraryMonitor: Error in Directory watcher for: \\192.168.1.1\Seagate_OneTouchHDD_1_2e3c\TV System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (64): The specified network name is no longer available. 2025-01-14 18:59:06.932 Error LibraryMonitor: Error in Directory watcher for: \\192.168.1.1\Seagate_OneTouchHDD_1_2e3c\MOVIES System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (64): The specified network name is no longer available. Edited January 14, 2025 by Lessaj
GauntFeatures 1 Posted January 14, 2025 Author Posted January 14, 2025 HI thanks what does that mean? i'm clueless
Lessaj 477 Posted January 14, 2025 Posted January 14, 2025 I don't use SMB so I can't really help much but make sure the SMB share is available and that Emby can access it.
GauntFeatures 1 Posted January 14, 2025 Author Posted January 14, 2025 Ok thanks i'll look in to that
Luke 42181 Posted January 15, 2025 Posted January 15, 2025 Was it offline when you tried to play? Please let us know what you find. Thanks.
GauntFeatures 1 Posted January 15, 2025 Author Posted January 15, 2025 What do you mean by offline? I activated all of the SMB features in turn windows features on/off. This morning most movies i click on are working. Then few minutes later they are not working and giving me the same error. Seems to be intermittent. I thought i had an unstable network connection but i checked that and was ok. Added latest log. ffmpeg-transcode-72170692-12da-4470-9c80-2b35838d91f0_1.txt
Luke 42181 Posted January 15, 2025 Posted January 15, 2025 5 hours ago, GauntFeatures said: What do you mean by offline? I activated all of the SMB features in turn windows features on/off. This morning most movies i click on are working. Then few minutes later they are not working and giving me the same error. Seems to be intermittent. I thought i had an unstable network connection but i checked that and was ok. Added latest log. ffmpeg-transcode-72170692-12da-4470-9c80-2b35838d91f0_1.txt 10.4 kB · 1 download Hi, can you please attach the main emby server log as well? Thanks.
GauntFeatures 1 Posted January 16, 2025 Author Posted January 16, 2025 Hi can anyone help with this, still having same error. Latest logs attached thanks embyserver (2).txt ffmpeg-transcode-2fef602d-ef1b-4054-b060-32389dba75eb_1.txt
visproduction 328 Posted January 16, 2025 Posted January 16, 2025 Possible related info: https://tachytelic.net/2019/09/windows-10-enable-smb1/ WIndows 11 disables older SMB versions for security reasons. https://superuser.com/questions/1763412/windows-11-cannot-access-routers-usb-storage
GauntFeatures 1 Posted January 16, 2025 Author Posted January 16, 2025 Thanks for the response i'll have a look into the links
Luke 42181 Posted January 16, 2025 Posted January 16, 2025 Could be a problem with the file: 09:35:14.231 built with gcc 12.2.0 (Rev10, Built by MSYS2 project) 09:35:14.231 Execution Date: 2025-01-16 09:35:14 09:35:14.449 [mov,mp4,m4a,3gp,3g2,mj2 @ 000002306398c440] reached eof, corrupted CTTS atom 09:35:14.449 [mov,mp4,m4a,3gp,3g2,mj2 @ 000002306398c440] error reading header 09:35:14.553 \\192.168.1.1\Seagate_OneTouchHDD_1_2e3c\MOVIES\WW2\Sink The Bismarck!.mp4: End of file 09:35:14.555 EXIT As a test, can you create an empty folder on your C drive, then setup a library based on that folder, and copy one of these videos into the folder. Then scan and locate the newly added video in your emby web app. Does it play from the C drive?
GauntFeatures 1 Posted January 16, 2025 Author Posted January 16, 2025 Ok done that and movie played fine on both browser and tv app. 1
GauntFeatures 1 Posted January 17, 2025 Author Posted January 17, 2025 The files on external drive attached to my router. I created local network folder.
GauntFeatures 1 Posted January 19, 2025 Author Posted January 19, 2025 I'm still having the same problem. Can anyone suggest anything?
Luke 42181 Posted January 23, 2025 Posted January 23, 2025 As a test, can you try attaching the drive to your server machine instead?
