Menelmar 1 Posted January 12, 2025 Posted January 12, 2025 Hi folks I have been using Emby (Premiere) with my media for quite some time, but recently I've discovered Live TV feature Trying to test it with DaddyTV playlist made by dtanktempse, filling in m3u and guide URLs, and filling Referer and User-Agent fields with strings provided in manual. Channel structure and tv guides load perfectly fine. But none of channels are working - "Forbidden" error shows up after click. I couldn't find where to put "Origin" field, and manual says that omitting it will cause 403 error when loading content. So what am I doing wrong, and could this m3u even be loaded and work properly on emby?
Luke 42241 Posted January 13, 2025 Posted January 13, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Menelmar 1 Posted January 13, 2025 Author Posted January 13, 2025 Luke, thanks for reply. I've already found a solution - using m3u-playlist-proxy makes channels work perfectly. But I'm still figuring out problem with xml guide timings - seems like channel time zones are not corrected relatevely to the my time zone. I don't know, is this my embyserver-side issue, or there's smth wrong with xml source
Luke 42241 Posted January 15, 2025 Posted January 15, 2025 On 1/13/2025 at 11:48 AM, Menelmar said: Luke, thanks for reply. I've already found a solution - using m3u-playlist-proxy makes channels work perfectly. But I'm still figuring out problem with xml guide timings - seems like channel time zones are not corrected relatevely to the my time zone. I don't know, is this my embyserver-side issue, or there's smth wrong with xml source Hi, have you checked the date and times in the xml data?
Carlo 4561 Posted January 18, 2025 Posted January 18, 2025 On 1/12/2025 at 9:41 AM, Menelmar said: Hi folks I have been using Emby (Premiere) with my media for quite some time, but recently I've discovered Live TV feature Trying to test it with DaddyTV playlist made by dtanktempse, filling in m3u and guide URLs, and filling Referer and User-Agent fields with strings provided in manual. Channel structure and tv guides load perfectly fine. But none of channels are working - "Forbidden" error shows up after click. I couldn't find where to put "Origin" field, and manual says that omitting it will cause 403 error when loading content. So what am I doing wrong, and could this m3u even be loaded and work properly on emby? You won't need to set Referer or User-Agent fields in Emby because you missed a step or two in the dtanktempse setup. You need to setup: M3U Playlist Proxy Easiest and simplest to get working Threadfin some people have trouble getting this to work Cabernet has a lot of features and plugins Emby will be setup to use the URL of the proxy which will vary depending on which one you use.
