Lordjohn1 0 Posted January 12, 2025 Posted January 12, 2025 Good day to you all. Currently emby-server.service will not start without manual intervention after i perform a reboot. I am on Pi5 running Pi os 6.6.64-v8-16k+ Debian Bookworm Quote After the system boots this is the systemctl status × emby-server.service - Emby Server is a personal media server with apps on just about every device Loaded: loaded (/lib/systemd/system/emby-server.service; enabled; preset: enabled) Drop-In: /etc/systemd/system/emby-server.service.d └─write-permissions.conf Active: failed (Result: exit-code) since Sun 2025-01-12 11:38:43 GMT; 24s ago Duration: 13ms Process: 762 ExecStart=/opt/emby-server/bin/emby-server (code=exited, status=226/NAMESPACE) Main PID: 762 (code=exited, status=226/NAMESPACE) CPU: 3ms Jan 12 11:38:43 64bitpi systemd[1]: Started emby-server.service - Emby Server is a personal media server with apps on just about every device. Jan 12 11:38:43 64bitpi (y-server)[762]: emby-server.service: Failed to set up mount namespacing: /run/systemd/unit-root/media/usb3/TV: No such file or directory Jan 12 11:38:43 64bitpi (y-server)[762]: emby-server.service: Failed at step NAMESPACE spawning /opt/emby-server/bin/emby-server: No such file or directory Jan 12 11:38:43 64bitpi systemd[1]: emby-server.service: Main process exited, code=exited, status=226/NAMESPACE Jan 12 11:38:43 64bitpi systemd[1]: emby-server.service: Failed with result 'exit-code'. After this i can start emby from the server and everything is fine. Regards John
Luke 42243 Posted January 13, 2025 Posted January 13, 2025 hi, is any emby server log file generated? Emby Server Data Folder
