AhmedNSane 1 Posted 3 hours ago Posted 3 hours ago For those who are still having the Forbidden issue, I highly recommend you self-host Dispatcharr via Docker. It makes everything a breeze. Just make sure you don't check the Direct Stream box, and you don't even have to to fill out the user-agent and referrer fields during M3U Tuner setup. See the screenshots below: If anyone needs more details about how to achieve this, I'll be happy to help. Take care, y'all!
xxtonixx 0 Posted 2 hours ago Posted 2 hours ago 1 hour ago, AhmedNSane said: For those who are still having the Forbidden issue, I highly recommend you self-host Dispatcharr via Docker. It makes everything a breeze. Just make sure you don't check the Direct Stream box, and you don't even have to to fill out the user-agent and referrer fields during M3U Tuner setup. See the screenshots below: If anyone needs more details about how to achieve this, I'll be happy to help. Take care, y'all! I've installed it, but when I enter the URL in the dispatcharr, it doesn't retrieve the channels. I get the following error: "Failed to establish a new connection: [Errno 111] Connection refused" I've entered the settings in my mobile IPTV app, and it works fine, but of course, I want to use Emby, which is more convenient.
