Boni340 7 Posted January 8, 2025 Posted January 8, 2025 (edited) Hi, I have 100000 strm files, each strm file has lot of links how can i choose when i click on strm file it will open a menu with all links inside and i choose the stream will play? is there plugin that do that? now it play only the first link can you advise me any other solution to do that for movies and episode i want only one item show in screen but when i click on it i see lot of streams to choose one sample of my streams (i can change it to any format) file name s01e01.strm inside this file lot of stream rows http://localhost:8080/stream/5788?hash=723423472d49 #s01e01a.mp4 http://localhost:8080/stream/5787?hash=772234234d49 #s01e01b.mp4 http://localhost:8080/stream/5786?hash=772678678d49 #s01e01b.mp4 http://localhost:8080/stream/5787?hash=77267345d49 #s01e01b.mp4 http://localhost:8080/stream/5787?hash=77267345d49 #sdfsdf (2024).mp4 can i play m3u file from strm ? that play all links inside the m3u file? how can i write it to do that in strm file? if i write the path to m3u file is not working thanks Edited January 8, 2025 by Boni340 and more info
Luke 42150 Posted January 8, 2025 Posted January 8, 2025 Hi, I’ve never heard of strm formatted like this before. Where did they come from?
Boni340 7 Posted January 8, 2025 Author Posted January 8, 2025 47 minutes ago, Luke said: Hi, I’ve never heard of strm formatted like this before. Where did they come from? i made them myself ... is there any solution for what i want ? one movie thumb or series episode and i can choose the stream i want ? i don't want to make 10...20... strm files with 1 stream link because i get 20 thumb for same movie at emby
ebr 16302 Posted January 8, 2025 Posted January 8, 2025 7 minutes ago, Boni340 said: because i get 20 thumb for same movie at emby Hi. Not if you use proper multi-version naming. Movie Naming TV Naming 1
Boni340 7 Posted January 8, 2025 Author Posted January 8, 2025 49 minutes ago, ebr said: Hi. Not if you use proper multi-version naming. Movie Naming TV Naming it's work great. with folders and " - " in names. thanks 1
tvipoli 0 Posted January 11, 2025 Posted January 11, 2025 (edited) On 1/8/2025 at 4:23 PM, Boni340 said: i made them myself ... is there any solution for what i want ? one movie thumb or series episode and i can choose the stream i want ? i don't want to make 10...20... strm files with 1 stream link because i get 20 thumb for same movie at emby How did you get to strm? Edited January 11, 2025 by tvipoli
Luke 42150 Posted January 12, 2025 Posted January 12, 2025 7 hours ago, tvipoli said: How did you get to strm? STRM Files
