Procrastination 1 Posted January 8, 2025 Posted January 8, 2025 Hello i am new to emby. When i enable english subtitles in playback my computer starts to make so much noise i cant listen to the show. i think it isnt downloading subtitles correctly. i cant understand what is written in the log. FAQ (https://emby.media/community/index.php?/topic/134949-subtitles-not-downloading/#comment-1410802) - Are you using your username for Open Subtitles? Yes. - Are you using credentials for opensubtitles.com, or .org. .com - Have you gotten a log? Yes. - Have you tried turning off Hash Match? Yes. Screenshots: embyserver.txt
Abobader 3484 Posted January 8, 2025 Posted January 8, 2025 Hello Procrastination, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
GrimReaper 4843 Posted January 8, 2025 Posted January 8, 2025 Quote When i enable english subtitles in playback You're playing that item in a browser: Quote 2025-01-08 00:22:54.766 Info Server: http/1.1 Response 200 to ::1. Time: 79ms. POST http://localhost:8096/emby/Items/161/PlaybackInfo?UserId=416673b5fa18451fb1e52d237b02ba7e&StartTimeTicks=3192738930&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=200000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows that doesn't support that particular subtitle codec your English subs are in - resulting in transcoding (and likely subtitle burn-in): Quote 2025-01-08 00:22:54.882 Info Server: http/1.1 GET http://localhost:8096/emby/videos/161/master.m3u8?DeviceId=8501d6cb-01ce-4ae7-be47-4ece0d97dacc&MediaSourceId=a68586a5a89ff7eea6a219f3c243ca95&StartTimeTicks=3192738930&PlaySessionId=3702f455fb6a4a77ad18a0f8990515bc&api_key=x_secret1_x&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=199232000&AudioBitrate=768000&MaxWidth=3840&AudioStreamIndex=2&SubtitleStreamIndex=4&SubtitleMethod=Encode&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=SubtitleCodecNotSupported. Since no active Premiere subscription - no HWA: Quote 2025-01-08 00:22:54.969 Warn App: Hardware acceleration is not available as it requires a valid Premiere Subscription meaning transcoding is done in software only, taxing your CPU (likely maximizing usage) and kicking your fans in high gear, resulting in: Quote my computer starts to make so much noise i cant listen to the show. You can provide ffmpeg log written for that session for more details. 1
Procrastination 1 Posted January 8, 2025 Author Posted January 8, 2025 Hello grimreaper thank you for the fast reply. 9 minutes ago, GrimReaper said: You can provide ffmpeg log written for that session for more details. Here is the ffmpeg log: ffmpeg-transcode-7cba97da-1c89-45fa-810f-42032098c332_1.txt as for possibles solutions based on your response: 1) i should switch from google to other platforms? 2) i should subscribe to emby premiere to activate HWA?
Solution GrimReaper 4843 Posted January 8, 2025 Solution Posted January 8, 2025 (edited) 5 minutes ago, Procrastination said: 1) i should switch from google to other platforms? No, as no browser (that I know of) supports PGSSUB subtitles. Quote "Codec":"PGSSUB","Language":"eng" 5 minutes ago, Procrastination said: 2) i should subscribe to emby premiere to activate HWA? You should actually just obtain external text-based subs (.srt); you can use Emby's download subtitles feature or download them externally and import into Emby. Manual Subtitle Downloads Edited January 8, 2025 by GrimReaper
Procrastination 1 Posted January 8, 2025 Author Posted January 8, 2025 19 minutes ago, GrimReaper said: Manual Subtitle Downloads It worked! for anyone wondering where to download: Also as a heads up do not download the "horriblesubs" option unless you want to get some weird subs. 1
