Ninko 78 Posted January 7, 2025 Posted January 7, 2025 Hi, Very strange problem just started. Around 11:50am everyday I get an email about 2 user policies being updated, but they actually haven't, or not from what I can tell. Any thoughts? Thanks embyserver.txt
sa2000 689 Posted January 7, 2025 Posted January 7, 2025 (edited) 3 hours ago, Ninko said: Very strange problem just started. Around 11:50am everyday I get an email about 2 user policies being updated, but they actually haven't, or not from what I can tell. Did you edit any user details/settings in server settings ? If not, you could enable Debug Logging and see if the log next time it happens would have some clues - see Debug Logging section here Edited January 7, 2025 by sa2000
Ninko 78 Posted January 7, 2025 Author Posted January 7, 2025 1 hour ago, sa2000 said: Did you edit any user details/settings in server settings ? If not, you could enable Debug Logging and see if the log next time it happens would have some clues - see Debug Logging section here No, not changed a thing, this is why it seems so strange and random. It's always the same 2 users as well, no one else. 1
Ninko 78 Posted January 8, 2025 Author Posted January 8, 2025 Happened again today at 11:50am GMT. I had the extra logging on this time. embyserver.txt
Solution sa2000 689 Posted January 8, 2025 Solution Posted January 8, 2025 (edited) 21 minutes ago, Ninko said: Happened again today at 11:50am GMT. Might be to do with the VirtualTV plugin. Could you remove that plugin and see if it goes away Seems to coincide with 2025-01-08 11:50:15.748 Info SecurityManager: Registered for livetv-virtual If it is not that, then would need to see more examples - perhaps taking copy of /var/packages/EmbyServer/var/config/users each day and zip and send me by PM the daily zipped copies and the logs from one or more times when it arises Edited January 8, 2025 by sa2000 1
Ninko 78 Posted January 8, 2025 Author Posted January 8, 2025 (edited) Ok, I've uninstalled that plugin, we're see what happens tomorrow. But having looked closer at any differences in user settings, it seems to only affect those who have "Live TV" access on, so you may be right. What I don't understand is why has it started just recently, I've had that plugin installed for ages. @pünktchenDon't know if you can chime in on this one? Edited January 8, 2025 by Ninko
pünktchen 1410 Posted January 8, 2025 Posted January 8, 2025 (edited) Yes, VirtualTV is updating the user policies with Tag restrictions. But it should only happen if not all users (with live tv access) are enabled for the channels in the plugin settings. Edited January 8, 2025 by pünktchen
Ninko 78 Posted January 8, 2025 Author Posted January 8, 2025 5 minutes ago, pünktchen said: Yes, VirtualTV is updating the user policies with Tag restrictions. But it should only happen if not all users (with live tv access) are enabled for the channels in the plugin settings. Right, there's my problem then, thanks @pünktchen
pünktchen 1410 Posted January 8, 2025 Posted January 8, 2025 Unfortunately that's currently the only way to hide live tv channels for some users. But it should also happen only once for each user unless you change the setting in the plugin or manually edit the Tags for those users.
Ninko 78 Posted January 8, 2025 Author Posted January 8, 2025 24 minutes ago, pünktchen said: Unfortunately that's currently the only way to hide live tv channels for some users. But it should also happen only once for each user unless you change the setting in the plugin or manually edit the Tags for those users. That's the thing, I've not changed anything for a long time and suddenly it's updating user profiles everyday at 11:50.
pünktchen 1410 Posted January 8, 2025 Posted January 8, 2025 2 minutes ago, Ninko said: everyday at 11:50 Is that about the time the guide refresh is scheduled?
Ninko 78 Posted January 8, 2025 Author Posted January 8, 2025 1 minute ago, pünktchen said: Is that about the time the guide refresh is scheduled? It might have been, I can't remember and I've uninstalled the plugin for now to confirm the problem.
Ninko 78 Posted January 8, 2025 Author Posted January 8, 2025 6 minutes ago, pünktchen said: If it is my plugin, ping me again. Thanks
