DJRumpy 0 Posted January 2, 2025 Posted January 2, 2025 Roku player is giving mixed results for selected audio. I have an encode of a movie that is in an MP4 format. All of the tracks show DirectPlay. I have two audio track. The first is an HE-AAC 80kbps per the MP4 spec and also the (default). The second audio track is a DD AC3 5.1 track (448 Kbps). If I select either track, the extra display info shows the selected track in the player. The stats for nerds ALWAYS shows the default track is being streamed, regardless of which track I select. The Dashboard shows the selected track that I choose in the player. At soem points, regardless of which track I choose, the audio doesn't even hiccup, indicating that it isn't actually switching tracks. When I choose the option to fix it under the gear, and then switch audio tracks, you get the short blips while it switches and re-streams. The displayed info described above stays the same regardless of the 'state' of the streaming audio. It appears to be a glitch in the 'Nerds' status, but honestly I'm not sure. Emby seems to think the video file is fine and all Direct Play across the board. On a side note, I've set the 'Home' display options to show my media, recently added, and so on, and chosen the default 'view' to be Movies instead of Suggestions under the preferences on the Roku. When I do this, the only thing I see in home are my media choices (similar to the folders view), and recent releases, and no other information is shown. I'm not sure what is going on there. Thanks for listening and appreciate any thoughts you might have on the above.
Luke 42239 Posted January 3, 2025 Posted January 3, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
DJRumpy 0 Posted January 3, 2025 Author Posted January 3, 2025 (edited) Version4.8.10.0 This is what I mean by the audio info displaying incorrectly. The main screen shows 5.1, which I selected. Nerds stats ALWAYS shows Stereo AAC regardless of what I pick. Dashboard shows selected audio. I'm also seeing an odd error in the EmbyServer.txt log. Yesterday I was able to change the audio. Today it doesn't seem to matter what I pick. The only time it change is when I use the 'FIX option under the gear (does the Paren indicate what state you are currently iN, or the state it will attempt to use to fix the issue (by that I mean Attempt Playback Correction (Transcode) Attempt Playback Correction (DirectStream) - Does this mean it will attempt to use DirectStream or it is currently DirectStreaming and will be forced to try transcoding? 2025-01-03 15:21:08.366 Info EncodingManager: Deleting segment /mnt/HD/HD_a2/emby/transcoding-temp/180BE8/180BE8_120.ts due to disk space. Available space: 0 The drive has about 55GB free at the moment so I assume this is probably some mapped/mounted virtual drive or Ramdisk? Edited January 3, 2025 by DJRumpy
DJRumpy 0 Posted January 3, 2025 Author Posted January 3, 2025 One other weird issue. The Dashboard keeps showing the above item regardless of what's actually playing. It will flash between the current playing movie and then back to the one that showed it was recovering from an error. The playing movie just looks normal (all directly and no errors_. The error "Now Playing" is shown in the attached.
ebr 16332 Posted January 4, 2025 Posted January 4, 2025 Hi. The dashboard is showing a completely finished item - not one that is currently playing. I think this is an instance of a "stuck" session. What happens if you restart your server and try again?
DJRumpy 0 Posted January 4, 2025 Author Posted January 4, 2025 The dashboard shows currently playing (hence the "Now Playing" title"). The red/green bars are what indicates any transcoding/transmuxing progress, not the now playing postcard itself. This last issue shows this stuck title even when nothing is playing. If I start a new movie, it will flash between the two every second or so. If I stop playing some other title then this one shows up again. Very glitchy.
ebr 16332 Posted January 4, 2025 Posted January 4, 2025 1 hour ago, DJRumpy said: The dashboard shows currently playing (hence the "Now Playing" title"). Right, but the green progress bar is all the way at the end - indicating the item has finished.
DJRumpy 0 Posted January 4, 2025 Author Posted January 4, 2025 It's a bit hard to justify that it's NOT for "Now Playing" when it will normally immediately disappear once you stop a movie from being played. The Green/Red bars are to indicate transcoding/remuxing status (and yes the green bar will show progress through the movie, but once the movie is done, the Now Playing poster will either update with the next title, or close if nothing else is being played). The visibility of the larger Now Playing poster is strictly related to what is actually being streamed from the server. The fact that mine shows up when nothing is being streamed from the server, and continues to show up even after shutting it down and restarting indicates a problem.
ebr 16332 Posted January 5, 2025 Posted January 5, 2025 20 hours ago, DJRumpy said: The fact that mine shows up when nothing is being streamed from the server, and continues to show up even after shutting it down and restarting indicates a problem. Yes, I know and I was indicating that that was actually the problem you are seeing here.
DJRumpy 0 Posted January 5, 2025 Author Posted January 5, 2025 (edited) Just to be clear, the issue with the 'stats for nerds' always showing the default AAC existed before this weird phantom 'now playing' poster. This problem did finally go away. I had to select shutdown in the server web interface then manually exit it in the OS, and then I just rebooted the server just to make sure it was clean. I haven't seen the odd out of space disk errors in the logs since the last reboot either. I think the server just got into an odd state and things went downhill from there. Since the reboot it's behaving a bit better except for the stats for nerds always showing the default audio rather than what's playing. I would consider all of the above a one-off. This happens on both an older Roku Ultra (model # 4660) and a new Roku Ultra 2024 (model # 4850). If I get a chance later today, I'll try it on my Apple TV (4K) and see what it reports. I've tried playing with the subtitles (enabling/disabling), as well as changing the default audio track (these are in an MKV container). Changing the default audio in the file DOES change the stats for nerds, but it again just reflects the current default audio track rather than what's playing. Oddly enough, with the same movie (4K HDR - 2 audio tracks: stereo HE-AAC 80kbps, and AC3 5.1 DD at 480 kbps and a text subtitle/subrip). When I set the default audio to the AC3 track, and I have audio and video transcoding and audio transcoding disabled, it plays without issue (other than demuxing the streams since I left that option on to allow it to switch containers). If I manually select the HE-AAC 2-channel stereo, it then tries to do a full transcode and fails. I know it supports HE-AAC, and it should also support that in an MKV container so I'm not sure why it would need to transcode just for switching the audio. Just really weird inconsistent results with transcoding and playback. On the bright side, if I set the default audio to AC3 5.1, then the stats for nerds does show the AC3 5.1, but it's the default so that may be where the issue is (it reports only the default audio, rather than what's actually selected). There's nothing too unusual about the source file. It's HEVC/H265, with a relatively low's bitrate of 14 Mb/s. The audio tracks are also pretty standard (HE-AAC Stereo@80 kbps and DD AC3 5.1@480 kbps). The subtitle is a plan text SRT. Hopefully some of this helps? Source File: Format : Matroska Format version : Version 4 File size : 13.1 GiB Duration : 2 h 11 min Overall bit rate : 14.2 Mb/s Frame rate : 23.976 FPS Movie name : Pacific Rim (2013) Encoded date : 2025-01-03 21:39:00 UTC Writing application : mkvmerge v88.0 ('All I Know') 64-bit Writing library : libebml v1.4.5 + libmatroska v1.7.1 / Lavf59.27.100 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@Main HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 11 min Bit rate : 13.7 Mb/s Width : 3 832 pixels Height : 2 156 pixels Display aspect ratio : 16:9 Original display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.069 Stream size : 12.6 GiB (96%) Title : Video Track Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.312700 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 2465 Maximum Frame-Average Light Level : 823 Audio #1 ID : 2 Format : AAC LC SBR Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication Commercial name : HE-AAC Format settings : Explicit Codec ID : A_AAC-2 Duration : 2 h 11 min Bit rate : 82.9 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 23.438 FPS (2048 SPF) Compression mode : Lossy Delay relative to video : -44 ms Stream size : 77.8 MiB (1%) Title : Stereo Language : English Default : No Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 11 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : -5 ms Stream size : 421 MiB (3%) Title : Surround Language : English Service kind : Complete Main Default : Yes Forced : No Dialog Normalization : -31 dB cmixlev : -4.5 dB surmixlev : -6 dB dialnorm_Average : -31 dB dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dB Text ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 4 min Bit rate : 54 b/s Frame rate : 0.218 FPS Count of elements : 1628 Stream size : 49.8 KiB (0%) Title : Subtitle Track Language : English Default : No Forced : No Menu 00:00:00.000 : Chapter 1 00:09:08.882 : Chapter 2 00:18:36.741 : Chapter 3 00:23:05.259 : Chapter 4 00:33:00.312 : Chapter 5 00:42:44.645 : Chapter 6 00:50:01.749 : Chapter 7 01:01:09.916 : Chapter 8 01:14:45.314 : Chapter 9 01:22:21.603 : Chapter 10 01:32:10.108 : Chapter 11 01:41:55.693 : Chapter 12 01:51:37.941 : Chapter 13 01:59:21.321 : Chapter 14 02:02:18.164 : Chapter 15 Edited January 5, 2025 by DJRumpy
Luke 42239 Posted January 10, 2025 Posted January 10, 2025 On 1/5/2025 at 10:36 AM, ebr said: Yes, I know and I was indicating that that was actually the problem you are seeing here. This should be much better in the upcoming 4.9 server release. Thanks.
Grimmer 15 Posted February 16, 2025 Posted February 16, 2025 I routinely experience both of these issues. The Roku chokes on alternate audio tracks when the source file is MP4. Only Roku has this problem. All other playback options I've tried (which is really only a handful) work just fine. When you switch the audio track and the main screen shows the new track but the stats for nerds shows the default... it is the stats for nerds that is correct. I have tested this with the default track being a different language. It never switches to the selected alternate English track, unless you do an "attempt to correct playback". But if you stop and restart the video you have to do the correction again. I have been using: ffmpeg -i input.mp4 -map 0 -map -d -c:v copy -c:a copy output.mkv to change files to MKV as I go. Note that I don't have any subtitles in my video files, so that command might need some tweaks. Roku correctly handles the selected audio track when the source file is MKV. I have stuck "now playing" tiles all the time. A Philips TV is the biggest culprit. I expect that the TV is turned off without stopping playback and it fails to send an "I quit" notification to the server and consequently gets stuck. The tile appears in the "now playing dashboard" yet there is no corresponding user session for it anymore. Rebooting the server gets rid of it; however, I have not noticed any ill effects from just leaving it there. I have left them there for several days at a time. I've had a third issue pop up with my new Ultra 2024. When I press the back arrow during playback to skip back 10 seconds it doesn't do it. Only a brief hiccup and continues. Then I close the control bar and press the back arrow again and it works properly after that (until playback it stopped and restarted). But this should probably have its own bug report thread... My older Roku Ultra versions did not do this, they behaved as expected.
