podonnell 48 Posted January 1, 2025 Posted January 1, 2025 Are there any internal tools or plugins that we can use to communicate with users? Or does this need to be done externally? Would love a message hub or way to display a message for a user upon login or such. Or, is this possible but there aren't any plugins that do it yet? 1
Luke 42254 Posted January 2, 2025 Posted January 2, 2025 Hi, there isn't anything that is an exact fit for this. A long time ago @chefhad a messaging plugin that I'm not sure is around anymore.
chef 3811 Posted January 7, 2025 Posted January 7, 2025 Hi! It's around. It might need a compatibility update. @podonnellare you interested in this? I can open the solution and see what it needs. Unless you found a different solution, then I won't bother.
podonnell 48 Posted January 7, 2025 Author Posted January 7, 2025 19 minutes ago, chef said: Hi! It's around. It might need a compatibility update. @podonnellare you interested in this? I can open the solution and see what it needs. Unless you found a different solution, then I won't bother. Hi, I'd love it! My next steps were looking into writing my own, so I've gotten nowhere else so far. If it's not too much trouble, would love to try yours out. Â
chef 3811 Posted January 7, 2025 Posted January 7, 2025 Okay, it's on the list. I'll link a build here when I'm sure it still works. Â 4
Untoten 306 Posted March 4, 2025 Posted March 4, 2025 On 1/7/2025 at 3:52 PM, chef said: Okay, it's on the list. I'll link a build here when I'm sure it still works. Â This would make me so so so happy please send to me also if you get it working.
podonnell 48 Posted June 25, 2025 Author Posted June 25, 2025 (edited) On 1/7/2025 at 4:52 PM, chef said: Okay, it's on the list. I'll link a build here when I'm sure it still works. Â Just poking back in to see if you were still hoping to look into this? If not absolutely no worries - I've been picking up development quite a bit lately and could start taking a look into a new solution. Just didn't want to recreate something if you had something underway still. Also, I would imagine this could only work on web browsers or such? Since the third party plugins I've seen aren't allowed on store apps, since that would have to be something Emby devs release themselves? Cheers! Edited June 25, 2025 by podonnell 2
