tbutz12 0 Posted December 30, 2024 Posted December 30, 2024 (edited) When using the feature to add a custom transcode folder, the repo binhex-emby does not add write permission to the custom selected folder via PATH mapping on the container. Example: When using the above path, and in emby doing a search for the folder under transcoding results in: To prevent this issue, I created a script that runs on startup that will add this permission. However, I think this might be a bug. Edited December 30, 2024 by tbutz12 Picture did not come through
Neminem 1623 Posted December 30, 2024 Posted December 30, 2024 I have been using ram drive to transcode. But it was a mess, when some stream ran wild, or grandma forgot to step back from live tv show, and just turned of the TV and not her firetv stick. Those transcodes would eat up my ram and impact my server in not so funny ways. At least you use /shm and not /tmp. /shm only allocates half you ram. In stead I use and old scrap ssd that I don't need. In my opinion you should stay away from ram drives when using emby.
Luke 42243 Posted December 30, 2024 Posted December 30, 2024 Hi, have you tried our official docker container?
Neminem 1623 Posted December 31, 2024 Posted December 31, 2024 If you really want to go down this road. !! You have be warned !! This should apply to Emby also.
Luke 42243 Posted December 31, 2024 Posted December 31, 2024 19 hours ago, tbutz12 said: Yes. It happens on both. How did you configure the docker volumes?
