podonnell 48 Posted December 28, 2024 Posted December 28, 2024 For my series library, i have TVDB first. In one instance there was no cast and crew listed for an episode on TVDB, but MovieDb(my second) did. I did have the data come through for cast and crew, so does it know to skip to a new provider when data is missing on the first one? If so, is it all or nothing? Or does it check for each aspect - episode description, cast crew, and other various data points, and then move between each provider and pull data if available? Also, for the refresh metadata every x days — does each item in the library have a date saved and independently search when that date comes?
Solution Luke 42183 Posted December 28, 2024 Solution Posted December 28, 2024 Quote I did have the data come through for cast and crew, so does it know to skip to a new provider when data is missing on the first one? Hi, yes it does. Quote If so, is it all or nothing? Or does it check for each aspect - episode description, cast crew, and other various data points, and then move between each provider and pull data if available? No, it checks for each field of data. 1
Luke 42183 Posted December 28, 2024 Posted December 28, 2024 Quote Also, for the refresh metadata every x days — does each item in the library have a date saved and independently search when that date comes? Yes. 1
