KeithA 5 Posted December 28, 2024 Posted December 28, 2024 Thanks for all of the work on the new Windows App. It is coming along nicely!! I have spent some time exploring it and have a question about music playback. When I select the playlist I want to play from the home screen, It opens giving me the option to select a single track or play the entire list. When I select either option a song begins playing and it is displayed at the top of the screen. When using a remote I am unable to navigate to it to click on it. Instead I have to go to the home screen to do so. I would think it should be possible to click on it without the need to go to the home screen. Additionally, when I click on it a new screen opens showing several covers that I can navigate through using left or right on my remote. My preference would be to default to the option you get when you select the icon all the way to the right on the bottom of the screen. It changes from having multiple songs displayed to a single one in the middle. Is there any way to change the default behavior? If not it may be something you want to consider. Thanks
softworkz 5133 Posted December 29, 2024 Posted December 29, 2024 6 hours ago, KeithA said: Thanks for all of the work on the new Windows App. It is coming along nicely!! I have spent some time exploring it and have a question about music playback. When I select the playlist I want to play from the home screen, It opens giving me the option to select a single track or play the entire list. When I select either option a song begins playing and it is displayed at the top of the screen. When using a remote I am unable to navigate to it to click on it. Instead I have to go to the home screen to do so. I would think it should be possible to click on it without the need to go to the home screen. Additionally, when I click on it a new screen opens showing several covers that I can navigate through using left or right on my remote. My preference would be to default to the option you get when you select the icon all the way to the right on the bottom of the screen. It changes from having multiple songs displayed to a single one in the middle. Is there any way to change the default behavior? If not it may be something you want to consider. Have you enabled TV Mode? Remote control input only works properly in tv mode - unfortunately. Settings >> Display >> Display Mode
KeithA 5 Posted December 29, 2024 Author Posted December 29, 2024 Yes, I have. Remote seems to work great other not being able to navigate the way I mentioned. This same issue applies to the xbox x/s as well. Thanks
softworkz 5133 Posted December 29, 2024 Posted December 29, 2024 Alright thanks! @Luke - are you aware of this?
