pgriffith 88 Posted December 28, 2024 Posted December 28, 2024 Hi softworkz, I have my PC running Emby connected to my Logitech receiver and using Emby Theater I have the following audio settings; But in the new App I only have this; Is this by design, a future addition or is mine broken somehow? I understand MPV is no longer used for audio, I am currently re-encoding AAC & EAC3 to AC3 using the following in my MPV conf [AAC 5.1 to AC3] profile-desc=AAC to AC3 profile-cond=(p["audio-codec-name"]=="aac") and p["audio-params/channel-count"]==6 af=lavcac3enc=yes:640:4 [EAC3 to AC3] profile-desc=EAC3 to AC3 profile-cond=(p["audio-codec-name"]=="eac3") and p["audio-params/channel-count"]==6 af=lavcac3enc=yes:640:4 Will there be a way to achieve this going forward, I have a LOT of content that is encoded using AAC?
softworkz 5133 Posted December 28, 2024 Posted December 28, 2024 3 hours ago, pgriffith said: I have my PC running Emby connected to my Logitech receiver What kind of Logitech receiver do you have? 3 hours ago, pgriffith said: But in the new App I only have this; Don't you see the passthrough option? It's only shown when you have "display syncing" (under Video Options) set to "Audio".
Solution softworkz 5133 Posted December 28, 2024 Solution Posted December 28, 2024 Ah, I see - the passthrough options are not shown in case of "digital out". This is fixed for the next update now. Thanks.
pgriffith 88 Posted December 29, 2024 Author Posted December 29, 2024 You da man softworkz Will there be a future solution for re-encoding now that MPV is no longer used? 1
softworkz 5133 Posted December 29, 2024 Posted December 29, 2024 39 minutes ago, pgriffith said: Will there be a future solution for re-encoding now that MPV is no longer used? MPV is still used (for video playback). 11 hours ago, softworkz said: What kind of Logitech receiver do you have? Which model?
pgriffith 88 Posted December 29, 2024 Author Posted December 29, 2024 Specifically audio re-encoding, as per my original post. It's the Logitech Z5500 system
