TylerDurden67 5 Posted February 4, 2025 Author Posted February 4, 2025 Hi @sa2000 By Moving to a New library,it works ok I tried with tv show like silo and all is fine. I think that something os wrong on my libraries configurations as the one by défaut created for test is working. Something maybe can cause an issue, the number of movies on the same folder and using nfo file. Thanks again for your help and sorry for the misunderstood 1
sa2000 696 Posted February 4, 2025 Posted February 4, 2025 It was a mixture of - nfo files resulting in English text being used - locked item stopping metadata refresh to correct the problem - metadata provider not having French text 1
TylerDurden67 5 Posted February 4, 2025 Author Posted February 4, 2025 7 minutes ago, sa2000 said: It was a mixture of - nfo files resulting in English text being used - locked item stopping metadata refresh to correct the problem - metadata provider not having French text And i still dont know how all of this was turned on... Anyway,i Can check all of this now. And i will re-order folders like movie a-m / n-z to limit files too
sa2000 696 Posted February 4, 2025 Posted February 4, 2025 40 minutes ago, TylerDurden67 said: And i still dont know how all of this was turned on... If you do find out how it arose, please let us know. There are library settings relating to nfo files and it would be good to know if the nfo files that led to English text being used were created by Emby Server or brought in from external sources Language settings are available for metadata for all libraries in Settings / Library / Advanced and also specifically at library level to override the default and at lower level on the media item to override the library setting And for nfo, there are settings under Metadata Readers and Metadata Savers
