Gryzor 27 Posted December 24, 2024 Posted December 24, 2024 (not sure if this is the appropriate board; my Emby instance is running on unRAID but this isn't, I guess, a platform-specific issue?) So, trying to simplify my login/user switching options I removed remote access for myself. I thought that this option has to do with out -of-lan access, but now I can't log in from within the LAN... any ideas about fixing this?
Gryzor 27 Posted December 24, 2024 Author Posted December 24, 2024 Ok so I solved it: had to reboot unRAID to gui mode and open a tab to Emby, but not using the IP but "localhost" instead. I guess this points to a configuration issue?
Solution Gryzor 27 Posted December 24, 2024 Author Solution Posted December 24, 2024 Yeah ok I was certain I had the correct mask in network settings but the values had disappeared, probably user error.
Neminem 1623 Posted December 24, 2024 Posted December 24, 2024 I hate when I do changes and forget to push that "save" button I happens for me sometimes. 1
Gryzor 27 Posted December 24, 2024 Author Posted December 24, 2024 5 minutes ago, Neminem said: I hate when I do changes and forget to push that "save" button I happens for me sometimes. That's my guess as to what happened, too
Gryzor 27 Posted December 28, 2024 Author Posted December 28, 2024 5 minutes ago, Luke said: HI, were you able to resolve this? Ah yeah, sorry, forgot to mark it as such. 1
