KRONZO 20 Posted December 23, 2024 Posted December 23, 2024 So i set this for a user But then in the dashboard I saw this Have i misunderstood something or has the user choosen playback 480p themselves ? Hope you can help, and merry christmas
Solution Happy2Play 9812 Posted December 23, 2024 Solution Posted December 23, 2024 26 minutes ago, KRONZO said: So i set this for a user But then in the dashboard I saw this Have i misunderstood something or has the user choosen playback 480p themselves ? Hope you can help, and merry christmas No that would suggest they have the client quality setting set to a lower value then you have the server set to. Other factor maybe the Auto setting as I am not sure if the default fallback setting has been updated on this client. Do you know what the quality setting is set to on that client? But would need to see server and ffmpeg log.
KRONZO 20 Posted December 24, 2024 Author Posted December 24, 2024 I figured it out, it turns out I still have 480p files 1
