Gilgamesh_48 1244 Posted December 23, 2024 Posted December 23, 2024 Some time ago I posted about wanting to be able to use the standard Windows right click menu inside Emby but I did not get any real resolution. I discovered a possible solution today where you can use the standard Window right click menu. 1. Pick an item 2 Right click that item and you will see the Emby right click menu. 3. With that menu still up Right click the item again. The Windows right click menu will appear. I have not had time, yet, to fully test if everything works as expected but I have confidence it will give me at least partial functionality. If i could have found my old thread I would have just added this to it but my searching skills seem to be lacking. I appears that the functionality is lacking in the Windows menu but at least i now know how to access that menu even if it is nearly useless.
Luke 42289 Posted December 24, 2024 Posted December 24, 2024 Hi, what do you want to do in that menu?
