KeithA 5 Posted December 23, 2024 Posted December 23, 2024 Is there a feature that allows you to move through a list using the number keys? On Kodi the numbers are alpha numeric. For example the number 1 is ABC. If you click the one 3 times you will move down the list to the first item that begins with C. I tried and it doesnt work that way on the new Emby windows app but it could be user error. Thanks
Solution softworkz 5133 Posted December 23, 2024 Solution Posted December 23, 2024 27 minutes ago, KeithA said: Is there a feature that allows you to move through a list using the number keys? On Kodi the numbers are alpha numeric. For example the number 1 is ABC. If you click the one 3 times you will move down the list to the first item that begins with C. I tried and it doesnt work that way on the new Emby windows app but it could be user error. No, only the WMC UI apps and web app have this, but not the regular Emby apps. see https://wmc.emby.media/
