Syunic 1 Posted December 22, 2024 Posted December 22, 2024 Hello, Am i missing something on the settings in emby/anime? The only setting i have is the ms so i dont get banned searching up metadata in anidb. i have no choice of genre or something like that. Im pretty sure there was some options like that. Im using the newest emby version, freshly installed. Thanks and merry christmas
Syunic 1 Posted December 22, 2024 Author Posted December 22, 2024 So it seems version 1.5.2 still has these options, 1.5.3 for some reason doesnt.
Syunic 1 Posted December 23, 2024 Author Posted December 23, 2024 1 hour ago, Luke said: Hi, what do you want to do with genres? Its not that much about genre, but the Title language. I want to swap to romaji
Luke 42180 Posted December 29, 2024 Posted December 29, 2024 OK we can look at adding an option to ignore the library setting and force romaji. Thanks.
Luke 42180 Posted January 15, 2025 Posted January 15, 2025 I've pushed an update to the Emby anime plugin. It has an option on the plugin config screen that will allow you to force the usage of Romaji. Thanks.
