yocker 1412 Posted December 22, 2024 Posted December 22, 2024 A friend of mine has problems playing certain videos that require transcoding on hes Samsung TV. I suspect it's when the video have "strange" audio numbers like fx. "8" channel instead of "7.1" but i can't be sure. ffmpeg-transcode-73752b71-6636-4e79-b04c-ff00a327107d_1.txt
Neminem 1621 Posted December 22, 2024 Posted December 22, 2024 (edited) @yockerlooks strange to me, but looks like your system has issues transcoding fast enough. 20:14:39.084 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.084 SegmentComplete=video:0 Index=0 Start=0.000000 End=3.003000 Duration=3.003000 offset_pts=0 start_pts=0 Frames=72 filename=40CDB2_0.ts 20:14:39.084 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_1.ts.tmp' for writing 20:14:39.088 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.088 SegmentComplete=video:0 Index=1 Start=3.003000 End=6.006000 Duration=3.003000 offset_pts=0 start_pts=3003000 Frames=72 filename=40CDB2_1.ts 20:14:39.088 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_2.ts.tmp' for writing 20:14:39.093 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.094 SegmentComplete=video:0 Index=2 Start=6.006000 End=9.009000 Duration=3.003000 offset_pts=0 start_pts=6006000 Frames=72 filename=40CDB2_2.ts 20:14:39.094 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_3.ts.tmp' for writing 20:14:39.098 elapsed=00:00:08.02 frame= 521 fps= 65 q=17.0 size=N/A time=-00:00:21.31 bitrate=N/A throttle=off speed=N/A 20:14:39.099 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.099 SegmentComplete=video:0 Index=3 Start=9.009000 End=12.012000 Duration=3.003000 offset_pts=0 start_pts=9009000 Frames=72 filename=40CDB2_3.ts 20:14:39.099 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_4.ts.tmp' for writing 20:14:39.105 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.105 SegmentComplete=video:0 Index=4 Start=12.012000 End=15.015000 Duration=3.003000 offset_pts=0 start_pts=12012000 Frames=72 filename=40CDB2_4.ts 20:14:39.105 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_5.ts.tmp' for writing 20:14:39.110 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.110 SegmentComplete=video:0 Index=5 Start=15.015000 End=18.018000 Duration=3.003000 offset_pts=0 start_pts=15015000 Frames=72 filename=40CDB2_5.ts 20:14:39.110 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_6.ts.tmp' for writing 20:14:39.113 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.113 SegmentComplete=video:0 Index=6 Start=18.018000 End=21.021000 Duration=3.003000 offset_pts=0 start_pts=18018000 Frames=72 filename=40CDB2_6.ts 20:14:39.113 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_7.ts.tmp' for writing 20:14:39.582 elapsed=00:00:08.52 frame= 564 fps= 66 q=26.0 size=N/A time=00:00:02.28 bitrate=N/A throttle=off speed=0.268x 20:14:39.809 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.809 SegmentComplete=video:0 Index=7 Start=21.021000 End=24.024000 Duration=3.003000 offset_pts=0 start_pts=21021000 Frames=72 filename=40CDB2_7.ts 20:14:39.809 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_8.ts.tmp' for writing 20:14:40.090 elapsed=00:00:09.03 frame= 608 fps= 67 q=17.0 size=N/A time=00:00:04.11 bitrate=N/A throttle=off speed=0.455x 20:14:40.598 elapsed=00:00:09.54 frame= 642 fps= 67 q=16.0 size=N/A time=00:00:05.51 bitrate=N/A throttle=off speed=0.578x 20:14:40.828 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:40.828 SegmentComplete=video:0 Index=8 Start=24.024000 End=27.027000 Duration=3.003000 offset_pts=0 start_pts=24024000 Frames=72 filename=40CDB2_8.ts 20:14:40.828 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_9.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:00:03 - TranscodingPosition: 00:00:05 - ThrottleBuffer: 3s (Treshold: 120s) 20:14:41.104 elapsed=00:00:10.05 frame= 673 fps= 67 q=14.0 size=N/A time=00:00:06.83 bitrate=N/A throttle=off speed=0.68x 20:14:41.609 elapsed=00:00:10.55 frame= 703 fps= 67 q=19.0 size=N/A time=00:00:08.07 bitrate=N/A throttle=off speed=0.765x 20:14:42.013 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:42.013 SegmentComplete=video:0 Index=9 Start=27.027000 End=30.030000 Duration=3.003000 offset_pts=0 start_pts=27027000 Frames=72 filename=40CDB2_9.ts 20:14:42.013 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_10.ts.tmp' for writing 20:14:42.109 elapsed=00:00:11.05 frame= 734 fps= 66 q=18.0 size=N/A time=00:00:09.35 bitrate=N/A throttle=off speed=0.846x 20:14:42.431 [q] command received. Exiting. [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing SegmentComplete=video:0 Index=10 Start=30.030000 End=31.448089 Duration=1.418089 offset_pts=0 start_pts=30030000 Frames=34 filename=40CDB2_10.ts elapsed=00:00:11.48 frame= 754 fps= 66 q=17.0 Lsize=N/A time=00:00:10.19 bitrate=N/A throttle=off speed=0.887x video:153758kB audio:454kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Speed should be higher than 1x to keep up. There is a AC-3 5.1 stream in the file, does it happen with that ? Adding. Jep guess its 8 channels part thats your issue. 20:14:31.051 [matroska,webm @ 0x81b3c0] Could not find codec parameters for stream 2 (Audio: truehd, 48000 Hz, 8 channels): unspecified sample format Edited December 22, 2024 by Neminem Adding
yocker 1412 Posted December 22, 2024 Author Posted December 22, 2024 1 hour ago, Neminem said: @yockerlooks strange to me, but looks like your system has issues transcoding fast enough. 20:14:39.084 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.084 SegmentComplete=video:0 Index=0 Start=0.000000 End=3.003000 Duration=3.003000 offset_pts=0 start_pts=0 Frames=72 filename=40CDB2_0.ts 20:14:39.084 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_1.ts.tmp' for writing 20:14:39.088 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.088 SegmentComplete=video:0 Index=1 Start=3.003000 End=6.006000 Duration=3.003000 offset_pts=0 start_pts=3003000 Frames=72 filename=40CDB2_1.ts 20:14:39.088 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_2.ts.tmp' for writing 20:14:39.093 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.094 SegmentComplete=video:0 Index=2 Start=6.006000 End=9.009000 Duration=3.003000 offset_pts=0 start_pts=6006000 Frames=72 filename=40CDB2_2.ts 20:14:39.094 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_3.ts.tmp' for writing 20:14:39.098 elapsed=00:00:08.02 frame= 521 fps= 65 q=17.0 size=N/A time=-00:00:21.31 bitrate=N/A throttle=off speed=N/A 20:14:39.099 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.099 SegmentComplete=video:0 Index=3 Start=9.009000 End=12.012000 Duration=3.003000 offset_pts=0 start_pts=9009000 Frames=72 filename=40CDB2_3.ts 20:14:39.099 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_4.ts.tmp' for writing 20:14:39.105 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.105 SegmentComplete=video:0 Index=4 Start=12.012000 End=15.015000 Duration=3.003000 offset_pts=0 start_pts=12012000 Frames=72 filename=40CDB2_4.ts 20:14:39.105 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_5.ts.tmp' for writing 20:14:39.110 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.110 SegmentComplete=video:0 Index=5 Start=15.015000 End=18.018000 Duration=3.003000 offset_pts=0 start_pts=15015000 Frames=72 filename=40CDB2_5.ts 20:14:39.110 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_6.ts.tmp' for writing 20:14:39.113 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.113 SegmentComplete=video:0 Index=6 Start=18.018000 End=21.021000 Duration=3.003000 offset_pts=0 start_pts=18018000 Frames=72 filename=40CDB2_6.ts 20:14:39.113 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_7.ts.tmp' for writing 20:14:39.582 elapsed=00:00:08.52 frame= 564 fps= 66 q=26.0 size=N/A time=00:00:02.28 bitrate=N/A throttle=off speed=0.268x 20:14:39.809 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:39.809 SegmentComplete=video:0 Index=7 Start=21.021000 End=24.024000 Duration=3.003000 offset_pts=0 start_pts=21021000 Frames=72 filename=40CDB2_7.ts 20:14:39.809 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_8.ts.tmp' for writing 20:14:40.090 elapsed=00:00:09.03 frame= 608 fps= 67 q=17.0 size=N/A time=00:00:04.11 bitrate=N/A throttle=off speed=0.455x 20:14:40.598 elapsed=00:00:09.54 frame= 642 fps= 67 q=16.0 size=N/A time=00:00:05.51 bitrate=N/A throttle=off speed=0.578x 20:14:40.828 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:40.828 SegmentComplete=video:0 Index=8 Start=24.024000 End=27.027000 Duration=3.003000 offset_pts=0 start_pts=24024000 Frames=72 filename=40CDB2_8.ts 20:14:40.828 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_9.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:00:03 - TranscodingPosition: 00:00:05 - ThrottleBuffer: 3s (Treshold: 120s) 20:14:41.104 elapsed=00:00:10.05 frame= 673 fps= 67 q=14.0 size=N/A time=00:00:06.83 bitrate=N/A throttle=off speed=0.68x 20:14:41.609 elapsed=00:00:10.55 frame= 703 fps= 67 q=19.0 size=N/A time=00:00:08.07 bitrate=N/A throttle=off speed=0.765x 20:14:42.013 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing 20:14:42.013 SegmentComplete=video:0 Index=9 Start=27.027000 End=30.030000 Duration=3.003000 offset_pts=0 start_pts=27027000 Frames=72 filename=40CDB2_9.ts 20:14:42.013 [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2_10.ts.tmp' for writing 20:14:42.109 elapsed=00:00:11.05 frame= 734 fps= 66 q=18.0 size=N/A time=00:00:09.35 bitrate=N/A throttle=off speed=0.846x 20:14:42.431 [q] command received. Exiting. [segment @ 0x867740] Opening '/transcode/transcoding-temp/40CDB2/40CDB2.m3u8.tmp' for writing SegmentComplete=video:0 Index=10 Start=30.030000 End=31.448089 Duration=1.418089 offset_pts=0 start_pts=30030000 Frames=34 filename=40CDB2_10.ts elapsed=00:00:11.48 frame= 754 fps= 66 q=17.0 Lsize=N/A time=00:00:10.19 bitrate=N/A throttle=off speed=0.887x video:153758kB audio:454kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Speed should be higher than 1x to keep up. There is a AC-3 5.1 stream in the file, does it happen with that ? Adding. Jep guess its 8 channels part thats your issue. 20:14:31.051 [matroska,webm @ 0x81b3c0] Could not find codec parameters for stream 2 (Audio: truehd, 48000 Hz, 8 channels): unspecified sample format Speed should not be an issue as transcoding works fine for other apps. Both streams in the video have "strange" channels numbers, the 5.1 is AC3 6 channel and the 7.1 is TrueHD 8 channel. Both streams do it. I have a none remux file of the same movie and that plays fine. Hes playing an video with EAC3 5.1 no problems at the moment. 1
SamES 1084 Posted December 22, 2024 Posted December 22, 2024 From your log in the first post: TranscodeReasons=ContainerBitrateExceedsLimit The bitrate of that file is 75Mbps, so there is either a limit set on the server or client, or that's too high for your connection. That's why it is transcoding
yocker 1412 Posted December 22, 2024 Author Posted December 22, 2024 (edited) 1 hour ago, SamES said: From your log in the first post: TranscodeReasons=ContainerBitrateExceedsLimit The bitrate of that file is 75Mbps, so there is either a limit set on the server or client, or that's too high for your connection. That's why it is transcoding Yeah sorry the title is a little misleading and i forgot to add everything about this, have had the worst hangovers so my head hasn't worked that well today. Plus somethings are a bit of a haze, the party got pretty high at one point. The movie doesn't play even when direct and no transcoding so i enabled transcoding for it by lowering the quality setting to see if that would work. Without any transcoding the server didn't even give a log about me having tried to play the file at all, with transcoding i at least got a log that i could show here. Reason for the high bitrate is that i normally use that video for testing, i normally only have very few files with that high bitrate on my server. The server usually have no problems with files like it, even multiples of them. I have tested with the same file other places and even on my phone via cellular connection and there are no problems. My friends connection should also be able to handle the file no problem, i believe he has a 300/300 line. I have no limit set on my server, people can stream at what ever bitrate they want. I don't have that many users and a 1Gpbs fiber connection so that shouldn't be a problem either. Other files works fine for him, so far only files with strange channel numbers have been a problem but i'm unsure that it's the problem. I hope that explains everything much better. Edited December 22, 2024 by yocker
