MartMH 1 Posted December 22, 2024 Posted December 22, 2024 When accessing my emby by using the remote website url through my web browser, all my folders show up empty and when trying to edit a user the settings are not loaded and the loading spinner keeps present and spinning. When accessing emby by using its ip address and port, this does not occur. The folders are containing content and the user settings are loaded. Good to note: the remote connection does see content in suggested mode. I'm using traefik and bunny.net as dns provider. I have disabled cdn. Docker services: emby: image: emby/embyserver container_name: embyserver restart: unless-stopped environment: - UID=1000 # The UID to run emby as (default: 2) - GID=100 # The GID to run emby as (default 2) - GIDLIST=100 # A comma-separated list of additional GIDs to run emby as (default: 2) volumes: - ./config:/config # Configuration directory - /media/mart/ssd_sata/data_samba/plex:/mnt/share1 # Media directory ports: - 8096:8096 # HTTP port - 8920:8920 # HTTPS port devices: - /dev/dri:/dev/dri # VAAPI/NVDEC/NVENC render nodes networks: - traefik labels: - "traefik.enable=true" - "traefik.http.routers.emby.rule=Host(`emby.mydomain.com`)" - "traefik.http.routers.emby.entrypoints=websecure" - "traefik.http.routers.emby.tls=true" - "traefik.http.routers.emby.tls.certresolver=bunny" - "traefik.http.routers.emby.service=emby" - "traefik.http.services.emby.loadbalancer.server.port=8096" networks: traefik: name: network_traefik_external external: true my traefik.yml: api: dashboard: true # Optional can be disabled insecure: true # Optional can be disabled debug: true # Optional can be Enabled if needed for troubleshooting entryPoints: web: address: ":80" # Optional if you want to redirect all HTTP to HTTPS http: redirections: entryPoint: to: websecure scheme: https websecure: address: ":443" providers: docker: endpoint: "unix:///var/run/docker.sock" exposedByDefault: false network: proxy # Optional; Only use the "proxy" Docker network, even if containers are on multiple networks. certificatesResolvers: bunny: acme: email: mail@mydomain.com storage: /certs/acme.json caServer: https://acme-v02.api.letsencrypt.org/directory # prod (default) dnsChallenge: provider: bunny delayBeforeCheck: 90 What could be going on? Emby version: 4.8.10.0
Luke 42243 Posted December 22, 2024 Posted December 22, 2024 Quote when trying to edit a user the settings are not loaded and the loading spinner keeps present and spinning. Hi ,can you please show a screenshot and attach the emby server log from when this happened? How to Report a Problem Thanks.
