JoeAverage92 6 Posted January 6, 2025 Posted January 6, 2025 On 1/4/2025 at 9:38 PM, generiq said: Something to consider here is that mpv by default will load embedded profiles. Looking at that site you linked, it appears that their samples have embedded profiles. Can you confirm if your test samples do or do not have embedded profiles? The video samples are encoded using Rec709 or BT2020 color scheme. The screenshots are a Windows capture, they just demonstrate that MPV is doing an ICC3DLUT conversion with the flag.
Guest Posted January 6, 2025 Posted January 6, 2025 39 minutes ago, JoeAverage92 said: The video samples are encoded using Rec709 or BT2020 color scheme. The screenshots are a Windows capture, they just demonstrate that MPV is doing an ICC3DLUT conversion with the flag. The samples are your own videos? They look like test samples?
JoeAverage92 6 Posted January 6, 2025 Posted January 6, 2025 28 minutes ago, generiq said: The samples are your own videos? They look like test samples? Yes it is video test samples from AVS HD 709 - Blu-ray & MP4 Calibration | AVS Forum (Rec709 mp4) and HDR10 test patterns set | AVS Forum (BT2020).
Guest Posted January 6, 2025 Posted January 6, 2025 22 minutes ago, JoeAverage92 said: Yes it is video test samples from AVS HD 709 - Blu-ray & MP4 Calibration | AVS Forum (Rec709 mp4) and HDR10 test patterns set | AVS Forum (BT2020). Do.you get the same result if you disable using embedded ICCs?
JoeAverage92 6 Posted January 6, 2025 Posted January 6, 2025 24 minutes ago, generiq said: Do.you get the same result if you disable using embedded ICCs? Yes. I believe that this flag only applies to image files (sRGB, Adobe, ...) not video files (Rec709, BT2020, ...).
JoeAverage92 6 Posted January 6, 2025 Posted January 6, 2025 (edited) On 1/4/2025 at 10:44 PM, generiq said: I just noticed that profiles only get added to SDR, because... This would explain why I saw no changes. Good idea. I have tested Automatic Color Management (Windows 11, 24H2) and, indeed, with this setting On, Emby displays correctly Red Rec709 (less saturated) and Red BT2020 on a wide gamut monitor, just as expected. However, according to Guide to Color Management Settings in Windows 10 and 11 - TruHu there seems to be problems with Automatic Color Management (but I did no investigate). Edited January 6, 2025 by JoeAverage92
TassLehoff 2 Posted February 23, 2025 Posted February 23, 2025 (edited) A friend told me colors are bad on his Xbox One X (not Series X) with a 1080p SDR TV, HDR tone mapping seem to work fine but not with Dolby Vision. Are there any options to configure? Edited February 23, 2025 by TassLehoff
Luke 42233 Posted March 5, 2025 Posted March 5, 2025 Hi, are you still seeing this with the latest update to the Emby Windows app?
TassLehoff 2 Posted April 1, 2025 Posted April 1, 2025 Sorry Luke, same as before on the last news of my friend. But is there something to configure ? I have personnaly the same probleme on android (phone and tv)
TassLehoff 2 Posted April 2, 2025 Posted April 2, 2025 (edited) I think i have found the answer of my question, if i understand profile 5 of Dolby Vision only work on Windows app What i can say: HDR / Without HDR Screen = Work on Xbox, Windows, Android TV and Android DV Profile 5 / Without DV Screen = Work Only in Emby Windows app I can't confirm for now if profile 8.1 play fine because all of my files who use this profile are HDR compatible Edit: I need to ask a friend but if i remember he can play fine a DV profile 5 on Android TV with a DV screen compatible Edited April 2, 2025 by TassLehoff
Luke 42233 Posted April 2, 2025 Posted April 2, 2025 OK please let us know if you find anything else. Thanks.
TassLehoff 2 Posted April 13, 2025 Posted April 13, 2025 I made some new test, and now i'm completly lost DV Profile 5 with good tonemapping: - Xiaomi Android TV compatible DV - Old chinese 1080p TV and a Android TV Box from a french ISP DV Profile 5 with bad tonemapping: - Old LG 1080p TV and a Android TV Xiaomi Mi Box
Guest Posted June 8, 2025 Posted June 8, 2025 This issue would appear to be the same, and would seem have come to a conclusion that is in same area. https://github.com/mpv-player/mpv/issues/16418
