Juanrendon 4 Posted December 20, 2024 Posted December 20, 2024 I currently made the backup on a server 1 to create a new server 2 and thus not have to scan the metadata again, the process was done successfully but I see that there is a kind of conflict in the creation of users on the new server 2, since when I create a user with Emby connect it is associated with server 1 and not server 2.
Luke 42243 Posted December 21, 2024 Posted December 21, 2024 Hi there, can you please provide a specific example? Thanks.
Juanrendon 4 Posted December 26, 2024 Author Posted December 26, 2024 On 12/21/2024 at 6:52 PM, Luke said: Hi there, can you please provide a specific example? Thanks. Hello good day, the problem was that the connect.txt file had the same id as the server where the backup was made, what I did was delete that connect.txt file and restart the server so that a new id would be generated and thus it would not have any conflict with the previous server, thank you
Happy2Play 9812 Posted December 26, 2024 Posted December 26, 2024 (edited) @Lukeshould the connect.txt be an option in the restore process like the serverid device.txt then? Or the setting apply to both files? Edited December 26, 2024 by Happy2Play
Luke 42243 Posted December 28, 2024 Posted December 28, 2024 On 12/26/2024 at 10:33 AM, Happy2Play said: @Lukeshould the connect.txt be an option in the restore process like the serverid device.txt then? Or the setting apply to both files? The one setting actually applies to both files. There is currently no reason to select them independently.
