whubbartt 1 Posted December 20, 2024 Posted December 20, 2024 Hi all; I've downloaded this same app file to multiple devices. The last working ver 3.4.28 but when I download it to my "Nvidia Shield Pro" and install it freezes on the splash screen. I never see the connecting circle. I've tried to deinstall/reinstall clear cache, delete, and reinstall again and it freezes every time. It never gives any prompts for login. I can download 3.4.20 from the Google Play Store and that seems to work fine on the pro. I installed 3.4.28 on my older Nvidia Shield and that works fine. It just will not run on my Pro unit. Any suggestions? This is perplexing and it makes no sense. Thanks
whubbartt 1 Posted December 20, 2024 Author Posted December 20, 2024 I just tried to update my phone which had 3.4.16 on it. My phone is a Galaxy Note S24 and I downloaded app and installed. It does the same thing just freezes on startup at the splash screen. I am starting to wonder if that is a good file on the emby website for android download app.
whubbartt 1 Posted December 20, 2024 Author Posted December 20, 2024 Where can I find 3.4.29? Google playstore has 3.4.20 and https://emby.media/emby-for-android.html The one there right now is what I tried and is freezing up. Is this 3.4.29? Is it possible it was a bad file loaded to web site if so?
whubbartt 1 Posted December 20, 2024 Author Posted December 20, 2024 The version I am trying to install is arm64
whubbartt 1 Posted December 20, 2024 Author Posted December 20, 2024 Ok looking at my installed apk's it is 3.4.29 that installed but it will not run. this is the version that just stays on splash screen
Luke 42242 Posted December 20, 2024 Posted December 20, 2024 OK 3.4.30 is up. Please try that. Thanks.
Solution whubbartt 1 Posted December 20, 2024 Author Solution Posted December 20, 2024 Thank You, 3.4.30 loads perfectly! I look forward to exploring the changes. 1
